OnStar phone vs cell range?
Greetings,
I've never been a fan of Onstar, but I've read that the built in phone may have more range than a typical cell phone. This is believable because it should have a better antenna, and also possibly more power. Here in East TN, my cell is often out of range on the fun roads, so it would be nice if the Onstar phone has more range.
Has anyone ever noticed a time when their cell was out of range, but the Onstar phone worked? To be fair, they'd have to both be on the same service, which I "think" is AT&T.
I'm waiting for a 2017 that's on order, which will be the 4th Onstar vehicle I've owned. I've never used the phone in the previous vehicles, but I might be willing to try it if there really is more range.
Thanks,
Rusty
Thanks,
Rusty
It is AT&T .. I doubt signal is better than a phone. FYI .. since it is AT&T .. you can add your C7 to your MobileShare plan so it shares your Data ... cost the same as adding an iPad .. $10/month.
Never used onstar. Didnt even know it had a phone on it. Luckily, my Verizon phone has never lost a signal. Well except in a few remote areas in Alaska. Cant see the point and dont use AT&T so no need for me.
It's a different world here in East TN. Roads I travel every day have no usable cell service from any provider, and they don't seem to have any shoulders either. It's a good thing cars are a LOT more reliable than they used to be
Cheers,
Rusty
Up until mid 2014 they used the VZ network, then they went over to the AT&T network. Check out the service foot print maps to see the coverage areas. Fun fact: AT&T actually leases towers from other providers so coverage areas are relatively similar.
Bigger antenna plus higher power (3 watts, versus less than 1 and usually closer to a half for handheld cell phones) means it almost certainly will get reception in more places than your handheld phone. Very few real-world reports of what that translate to in the area you are in. I do recall a post on one of the car forums (not here) that someone who was in the mountains of NY got reception with Onstar he could never get with his cell. That was when Onstar was on Verizon though.
13brv3 (10-16-2016)
There are clearly differences in phone reception, and my Galaxy S7 gets better reception than my Gear S2 watch. There are a lot of compromises made in electronics to squeeze it all into a small package that uses minimal battery power, so there's reason to hope that the cellular system in a car will do better than the phone.
I was just curious if anyone had experience with this, but in a month or so, I guess I'll be able to test it for myself.
Cheers,
Rusty
Check out this link, as it may answer many questions.
https://www.onstar.com/us/en/services/coveragemaps.html
If I remember correctly the OnStar phone is better as its a satellite phone where the cell phones use towers. At least that's what I was told or read or something. When I drive from Iowa to Arizona there are a few places where cell phone reception is non existent. In those cases, when needed, I have used OnStar.
Greetings,
Thanks,
Rusty
Thanks,
Rusty
My guess is maybe you need a different cell phone carrier or have a friend ride with you in your car to check out the signal on their phone !!! I have a friend who lives near me and his cell service ( new tower) is only 1 or 2 bars ( Verizon) and mine is 3 or 4 bars T-Mobile !!! Wayne
Terrain is the issue, and lack of towers, so a weak signal is the best you can hope for most of the time. In many areas the best cell phone in the world likely won't get a signal, but if the built in phone can improve my range, it might be worth dealing with Onstar.
Cheers,
Rusty
Received 8,928 Likes
Greetings,
Thanks,
Rusty
Thanks,
Rusty
I have OnStar turned on in all 3 of my vehicles. I have the lowest cost plan on each. When it comes to dealing with OnStar they are no where near the worst company to deal with. I have never been cheated by them or treated disrespectfully like XM used to do after Sirius took them over. They were bad. It was like dealing with one of those crooked stock brokers. Luckily, over the last few years they seemed to have cleaned up XM's act.
Bill
13brv3 (10-23-2016)
I can tell you from first hand experience that the car has greater range than any hand-held cell phone.
I was in a remote section of NM, and came across a horrific one car accident. There were perhaps a dozen + people who were already on the scene, but when I called OnStar and informed them, they told me I was the first to call for help. I stayed and relayed info via OnStar until the first responder arrived (with whatever radio setup they had) and it was over a half-hour until the ambulance arrived. AFAIK, they still had no other phone communication, but me.
13brv3 (10-23-2016)
Thanks to you both. That's really encouraging! I joke that if you go off the road around here, no one will ever find you, and you can't call for help even if you're still conscious. I have a 2014 Silverado that I never even activated, and I bet that shark fin antenna on top is better than what the Corvette has hiding under the skin. When I do the factory tour, I need to remember to look for the antenna.
Thanks,
Rusty
Thanks,
Rusty
Old thread but...
I've lost reception once in a freaking Sonic.
Even when I was over 30 miles out of range from service on my phone in rural mountains in Washington, I still had service via onstar.
Everyone uses my car when we go camping for phone calls etc. Lol
Greetings,
Thanks,
Rusty
Thanks,
Rusty
No experience in the Corvette, but I live in Middle Tennessee and for many years I had a lake house at Center Hill lake. In my work 2007 Silverado, the only way to make a call from our remote Lake House was with Onstar. Many tried with Verizon, ATT, and (lol) Sprint and all failed. But had flawless reception with the Onstar. Back then they were using Verizon. Most signals stopped when the asphalt turned to dirt roads near Austin Bottom. Onstar worked all the time.
I purposefully kept minutes on the plan just for that reason as we liked to use poor judgement and make terrible decisions while at the lake. Just in case we needed an ambulance or a pizza delivered.
Amblance or pizza? Both good reasons.
