Wouldn't this engine be perfect for the Grand Sport?
is producing more DF, therefore lower top end.
The following 3 users liked this post by jwbert:
E-Ray, 3LZ, ZER, LIFT
Received 9,608 Likes
Some of you guys are tough! Decided to compare the power and torque curves-both from GM. I picked several points and estimated best I could from the graphs. Presented the results in a table.
Note peak torque occurs at 4000 rpm with the LT1 at ~450 ft-lbs. With the LT376-535 in occurs @5000 rpm at ~460 ft-lbs and stays pretty flat thru red line where the LT1 drops off above 4000. Typical of what you get with larger ports and a high lift more aggressive cam. If your tracking that is where you want the power, just shift more! One Press Release says the redline is extended to 6800 rpm, quoting: "The impressive 535 naturally aspirated horsepower is thanks to CNC-ported heads and the high-lift LT1 Hot Cam. Not only does it make significant horsepower numbers, this engine also loves to rev, making great power all the way to its 6,800 rpm redline."
No doubt GM set the cam timing for max power as that is what folks mostly compare! If you want more torque with a sacrifice in power just retard the cam timing!
They do say: "Gone is the variable valve timing and Active Fuel Management, sacrificed in the name of performance and piston-to-valve clearance." That is a factor in the LT1 for street driving and why the engine has a broad torque curve. For my driving would not want that eliminated! Not a big deal when racing as it is probably fully advanced at the rpms used.
Glad I'm not the only one who gets it. The thing about progress is that the next generation should be better than the one it replaces, it's that whole "Improve from our past" thing.
Agreed, all the Z06 owner drive-by posts to inform us how inferior we are are infantile. Maybe there isn't enough action in the Z06 section to keep them occupied.
The following 2 users liked this post by Foosh:
2cnd Chance (11-01-2016),
JerryU (11-01-2016)
Quite doing stop light drags years ago to prove I have a faster car! Only the local horses and cows watch my ProStreet Rod with its 8.2 Liter BB make the occasional 0 to 60 run on our empty rural roads! And they don't care that the car is fast!
Foosh (11-01-2016)
I don't know about more power initially for the Stingray.
It is a very quick car for the street with excellent handling.
It's hard to top when compared to other Sportscars (not talking about Supercars).
I agree...and I have a Z06.
It is ridiculous and out-of-bounds to attack the Z06's cousins the Stingray and Grand Sport.
(facepalm)
How is it that an in over a decade of internet message boards, hp vs tq still isn't understood?
#33
The following 2 users liked this post by DAFFYDRUNK:
Niemienator (11-02-2016),
Z06Rob (11-01-2016)
#36
#37
No, I agree as well. In fact looking at what is accomplished with the more aggressive cam and ported heads the driveability for normal use would be worse! I like the low end torque the variable cam timing provides with the LT1.
#38
I've had a lot more HP in even lighter cars, and am smart and mature enough to have learned it's ridiculously unnecessary in a street car. Hell, 460HP in a 3300 lb. car on the street is pretty ridiculous as well.
As Jerry said, with the low-end torque and drivability of the LT1, it's just about the perfect, fun to live with, high-performance street engine. Moreover, I just really prefer normally aspirated engines.
sunsalem (11-02-2016)
#39
With that cam I doubt that it would pass emissions certification or EPA fuel economy, to be used in a production car.
That's why it's a crate engine for your 1966 Nova.
But, it would be one hell of a nice engine in a GS.
#40
You hit it right on the head. Looking through the GM performance catalog, the heads/cam kit isn't legal for installation in California. This engine is literally and LT1 with the h/c kit, so it wouldn't pass emissions in California (and maybe some other states).
