Esco jack stands?
Esco jack stands?
Looking to buy four jack stands, and found these while searching through the internet. They get good reviews, and I like the rubber tops.
I'm wondering if anyone has them, and how they like them, compared to other they might have used.
They make two sizes (13-21 inches), and a shorty ( 11-17 inches).
My floor jack will raise to 20".
Any input, or reason, from you fellows that do a lot of your own maintenance, to get one over the other would be greatly appreciated.
http://www.reverselogic.us/jack-stands.html
L8ter (11-06-2016)
E-Ray, 3LZ, ZER, LIFT
Received 9,606 Likes
They also make a cleaver jacking pad. When going to a dealer or tire shop you can bolt their pad to the Vette tempoarially. I always have to go through a speech to the service scheduler to ask that mechcanics use my aluminum jack pads I put in a clear plastic bag on the passenger seat. Will they all and always do as I ask, who knows?! With the Reverse Logic pads I would have no question and not worry that my rocker panels would be cracked! They are not meant to stay attached but fine for a short trip for service.
Another thought. I would not work under a car supported with 4 jack stands. Note the warning on a pair on mine in pic below. When I change oil, to get the car level, I made a pair of wooden stantions from a 2X6 and some plywood.
Made 6 Inch High Wood Stanchions To Use When Needing The Whole Car Raised
Note, the warning label on two of my jack stands says to use only one end of the car! When changing oil to get the car level I use homemade stanchions under the rear tires. The last warning on that label, although written by a lawyer, says not following these warnings can lead to death! Unfortunately it does happen, be safe.
L8ter (11-06-2016)
L8ter (11-06-2016)
I agree with Jerry, when I installed my headers I used a combination of race ramps, wood blocks, jack stands, and two floor jacks...Here's a photo prior to me sliding the ESCOs under the rear of the car. You can barely see them under the front of the car, but they are up there too...
Started working on cars at a very early age with my dad. We would place the jacked-up car frame (all cars in the day had frames) on cement blocks (our jack stands.) Then pop would make me hit the car width my shoulder. As he said, "if it's going to fall, better now then when you're under it replacing a muffler etc." He had a friend die when a car fell on him!
Thanks for the feed back gents!
And I do appreciate the safety heads-up.
I have plenty of 2 x 12 x 4' pieces left over from building my shop/barn. I think they will make quite hefty supports for working under the car. Although after I put them together it will take my tractor to move all four at once.
Better safe than squashed!
JerryU (11-06-2016)
Got the taller ones from Fred at Reverse Logic while on sale (gold tone stem the last in photo to the right. 10498). Work great!! Perfectly fit the jacking points.
Hey Fred, if you are reading this, suggest you make some replacement rubber tops that are twice as thick, or a little more for that extra protection and thickness to keep the jack at a greater distance away from the rockers. Just an idea. Almost like having a half-sized jacking pad seated to the jack itself. The stock pad is nice but a tad too thin.
Received 1,694 Likes
St. Jude Donor '15
I really like these:
http://www.jackpointjackstands.com
They just have them priced too high. I would pick these up in a heartbeat at a lower price, just something else for you to look at.
L8ter (11-06-2016)
St. Jude Donor '15
Yeah, that's what stopped me too. It is a really clever invention though.
I have used the ESCOs for several years now and am very satisfied with them.
I came across this thread, and if the prices are real, are unbeatable: http://www.1addicts.com/forums/showthread.php?t=1311312
(I have no affiliation and due diligence would have to be followed regarding the seller.)
When I was researching jackstands I found this comparison which lead me to choose the ESCOs: http://revlimiter.net/blog/2010/07/mega-jack-stand-review-1/
Hope this is helpful.
