Helpful if you change your own oil
Forget using any wrench.....I have used these on my last two cars and bike and they are excellent.
https://www.stahlbus-us.com/oil-drai...fc1ef5vk0t0ol6
The following 2 users liked this post by Glen e:
Flyingscot (11-16-2016),
nmvettec7 (11-17-2016)
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
BrunoTheMellow (11-17-2016)
Replace the plugs with magnetic ones.
You do know that a 15 mm 6 point socket is the same size as a 15 mm 6 point box wrench right? Sure spend the money, it only takes 1/4 turn to loosen it. But it's not necessary.
Use the right size, keep the socket square, no way you'll mess up a bolt unless you're over-torquing it.
Received 19,287 Likes
'20-'21-'22-'23-'24
Never had a problem using a socket, but I usually do use a box end wrench to loosen the drain plug.
Still, the worst part of the oil change is the filter change. But removing the plug with the short burst of oil flow can cause a mess as well, and this eliminates that portion of the oil change mess.
Will update after the oilchange, as I asked for feedback on clearance for this valve from drysump owners and got no response. Only from Glen e who had it installed on a wetsump.
E-Ray, 3LZ, ZER, LIFT
Received 9,619 Likes
Can't understand the issue of not using a quality 6 point socket. I buy products and some tools from Habor Freight but only buy quality wrenches.
In fact the first time I removed the side plug from my Z51 pan, a 3/8 inch ratchet was not enough to loosen the plug. Put on an adapter for my 1/2 inch ratchet. Granted was at an angle under the car but it also did not loosen! Just slipped on my 1/2 inch drive plybar and it started with a snap. Appeared to have blue Loctite on the threads?!
The plug head was fine but replaced both plugs with quality, strong magnetic drain plugs.
#33
Oil filter mess
Yeah, the plug on the side is very close to the oil cooler. I was able to get the quick connect and hose installed to test it, and the hose does touch barely, so I will see how it drains on this upcoming oil change.
I punch a hole in the bottom of the filter with a center punch. Let it drain through the hole and then spin it off.....no mess!
The following 2 users liked this post by Itshakes:
davekp78 (11-17-2016),
LagunaSecaZ06 (11-17-2016)
#34
Once again, you can eliminate the filter mess by using a 1 gallon Ziploc bag. Loosen the filter, snake the bag opening over the filter and keep loosening while in the bag. Once it gets loose, it falls right in the bag, no mess, and you're ready to install the new one. I've been using this for about 10 years and it works perfect.
Dif (02-25-2017),
SharkGrayStingray (11-17-2016)
#35
#38
I have, among other tools, this 6-point shallow socket set with inch/metric sockets that I use for tighter access. Works great.
This is on my C5, which has limited access to the oil pan drain plug, but illustrates how it makes the job easier.
#39
#40
Received 4,683 Likes
