★NEW! Cleartastic GS & Z06 Rocker, Brake Duct, & Door Paint Protection Kit!- FREE S&H
Premium Supporting Vendor
NEW!! Cleartastic Plus Rocker, Brake Duct, Lower Door & Brake Duct Leading Edge DIY Paint Protection Kit!
RIGHT NOW FREE SHIPPING & HANDLING
________________________________________ _____
Your GS or Z06 comes with very little paint protection film in a very vulnerable area. Only half of the panels are covered?!
Not only will your paint get chipped but over time you will have an unsightly line (where their film ends) running right down the middle of your panel!
Our new DIY paint protection kit covers the entire area! It goes edge to edge for more protection. No unsightly lines. The film becomes invisible once applied.
Your brake duct, the rocker area and the lower portion of your door are protected.
PLUS our kit also includes a piece to protect the leading painted edge of the brake duct!
Cleartastic Plus is a clear flexible film that creates an invisible barrier between your beautiful delicate paint and rocks & debris. Pre cut & designed for a simple easy application. Cleartastic Plus prevents paint chips, stains & withstands harsh weather and extreme high speeds.<br>
The film has “Self Healing” Characteristics so scratches, swirl marks & nicks will vanish automatically overtime! <br>
Cleartastic Plus has a mild adhesive to make it a “set it and forget it” film. One time application provides years & years of protection. Smooth as glass appearance make it invisible once applied. Wash & wax over the film. Treat it like your paint.
We designed these kits to ensure a perfect fit & easy application. Each kit comes with easy step by step directions on removing the factory film and applying the Cleartastic plus film.
To help launch this new product, FREE S&H (lower 48) to our forum friends!
Just click here to check it out and securely order! :
http://store.cleartastic.com/clplrobrdudo.html
Cleartastic has been protecting paint for almost 20 years. ...a name you can trust. It truly is The Clear Choice In Paint Protection.
Thank you!
First round of orders are out! Should get there in plenty of time to be under the tree!
Thank you for your business!
Ed
Ed
__________________
Number 1 "Do It Yourself" Protection Kits Since 1996
*Serving The Corvette Forum Members For 20 Years!
*Invisible Once Applied
*Tough As Nails Protection
*Saves You Time, Money & Of Course Your Paint
*Proudly Made In The USA
CHECK OUT OUR NEW WEBSITE! http://www.cleartastic.com
