What's this license plate holder
Hey guys,
I was wondering what is this license plate holder? is this removable or its permanently attached to the grille?
Thanks for your help
In states requiring a front plate, GM will add to the order. I believe they were $15.00.
They are removable. My dealer asked if I wanted the plate holder installed or not. As I live in a state requiring a front plate, I had it installed.
Hope this helps.
Hope this helps.
I have one still in the plastic bag. FL does not require a front plate.
Avanti (02-26-2019)
Picture is of an AERO PLATE not a front plate holder although many living in states requiring front plate use it as a plate holder. The front plate holder goes up over the grill onto the painted nose piece and the license plate is not bent as it would be if used with the aero plate. Many post on aero plate and modifying it for front license plate use.
Avanti (02-26-2019)
Received 8,930 Likes
Bill
If the stock front plate holder is installed then removed are holes left in the from bumper like with the C6?
ZenicaPA (02-01-2017)
Fun fact: the Aeroplate was, at one point, presented by GM as a front plate holder.
In the MY 2014, the big books on the dealers' showrooms that showcased the different features of all the different cars, there it was in living color stating that it is indeed a front plate holder, even though the frame that came with the car said it is not a plate holder. It also was not actually available in Carbon Flash.
I put on a tinted cover. Bad pic but it takes the focus off the plate.
I use the Aero version on my '14. There are even dimples in the bracket indicating where the holes are for the plate so it was obviously designed initially for use as a plate holder. I've never had any issue in MN re the height of the plate; it seems as long as you're displaying one you're fine. Never had any overheating issues with it blocking as it does cover a portion of the open grille area.
