View Poll Results: What Do You Do To Prevent Flat Spotting?
I leave the wheels on the car but get the weight off the tires by placing it on jack stands
1
1.49%
I use a product like flatstoppers or simpler product to reduce flat spotting.
8
11.94%
I just check the tires pressure often keeping them at the proper pressure
10
14.93%
I park and leave it until it's time to drive it again.
48
71.64%
Voters: 67. You may not vote on this poll
How to store your tires for the Winter to avoid flat-spotting
Avoid flat-spotting and choose your own tire-storage adventure.
http://www.roadandtrack.com/car-cult...s-this-winter/
http://www.tirerack.com/tires/tirete...jsp?techid=42&
What do you do?
Poll is for those who put their car in storage for the winter or leave it sitting for more than a month.
What do you do?
E. Over-inflate to the high 30's and not worry.
Unless you are barning the car (leaving it for years), that's all that is necessary.
JRYELLOWCORVETTE (12-22-2016)
SoCal Events Coordinator
St. Jude Donor '12
Fortunately for those of us out west our winter storage stints are usually no more than a couple days or a week at worst. But I used to live at 7000 ft in mountainous terrain where the roads were covered with "cinders". Cinders are crushed volcanic rock and with the corvette stickey tires, the volcanic rock would just eat paint behind the wheels so winter driving was infrequent. During that time I'd just store the car on the tires and forget about it until the roads were clear.
Over inflate by 5 psi and that is it. Been doing this for many years and never a problem.
Folks, tire technology has come a long way. These tires do not develop flat spots. That said, to ease your mind, feel free to increase tire pressure to 40 lbs, and if stored on concrete floor place a strip of carpet underneath.
The following 3 users liked this post by capecodvette:
I leave my car on its roof. Because it is a rag top, I put a towel on the garage floor first so as not to scuff the material.
The following 3 users liked this post by AdventurePoser:
But even on the rare case that they do get flat spots, they bounce back very quickly and round out after a few miles of driving (I've experienced this myself). They don't stay as flat spots forever.
Yep, I've experienced it myself also. Drive long enough for the tires to warm up and the warbling goes away. Living in the mid-Atlantic region, my car is normally only stored for short periods, typically no more than s month. However, over extended periods of time (3 months or more?) it is possible for permanent damage to be done.
Maxie2U (12-22-2016)
Put a sheet of pink foam insulation under each tire; provides the same benefit as the Flatstopper product at a fraction of the cost (much like the hockey puck vs. jacking puck debate).
What do you do?
What do you do?
My experience does not agree with the long term storage damage potential. I stored my 2016 for 4 1/2 months last winter. They may have been slightly flat spotted when I took it out for the first drive but they cleared up within the first mile or so. I have also winter stored my 66 Corvette with Goodyear radials for 30 years, no issue. My 70 442 was stored on Goodyear radials for 30 years with no issue. Last year I put reproduction Poylglas GT bias ply tires on it. It was stored over the winter and came out in the Spring just fine.
The following 4 users liked this post by Foosh:
Boiler_81 (12-22-2016),
Crossed Flags Fan (12-22-2016),
ExRedRacer (12-23-2016),
Jimmer1 (12-23-2016)
I over inflate the tires then wait for a warmer day and pull the car out of the garage roll it down the driveway then back in again to assure the tires are now repositioned. I try and accomplish this at least 3 times while in storage.
http://www.tirerack.com/tires/tirete....jsp?techid=42
Or these folks
http://papers.sae.org/2015-01-2196/
Yes, I know it can be permanent, and I also know that permanent damage is exceedingly rare. The SAE article is credible, but most interesting was their finding that it's far more likely when a car sits for extended periods at very high temperatures.
^^I agree that the likelihood of permanent flat spotting in most circumstances is minimal. As I stated earlier, my experience has been with temporary flat spots resulting from relatively short periods of time.
The point in providing references was simply to show those that don't believe permanent flat spotting is possible, that it is indeed possible and does happen, however rarely.
