Trunk barely popping up
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,819 Likes
2015 C7 of the Year Finalist
I KNOW I've seen a spring that can be added to give more "oooomph" to the "push up" when you try and open the trunk or hatch but my search has proved to be futile. Damn...
After my trunk has sat closed for a few days, when I pop it open, it barely comes up. It doesn't come up enough to get my finger under to fully open the trunk. After it is opened and the gasket has time to un-mash, the trunk pops up satisfactorily to where I can get my fingers under and fully open the trunk on succeeding open/close actions.
Anyone got a link to where I can get the stronger spring to push up the trunk to where you can get a finger under the lip and fully open the trunk?
Elmer
Elmer
My car's trunk just unlatches, you have to physically open it. Same operation, Both the 2014 and 2017 convertibles. The 2017 has the auto latch.
Received 8,926 Likes
It always unlatches but it doesn't pop up enough to get your fingers under the lip to lift it fully open.
Elmer
Elmer
I think the OP is talking about the trunk, not the hatch. Two different things for this question.
The posts on the corners can be tweaked to give more pressure up, but this may also result in more pressure to close (balancing act, here). I occasionally have to back them out to get more upward pressure on my C6; I haven't had to do this yet on my '14, but it's bound to need it eventually.
The only spring mentioned that I can recall was using a spring from a soap dispenser. It doesn't rust and remains very stiff for a long time.
I'm talking trunk, as in convertible trunk. A hatch is on the coupe and the hatch has a big hunk of glass in it.
When I open the trunk, it barely pops up and the gap is too small to get a finger under the lip to raise the trunk.
I just hit the gasket with silicone and I need to let the trunk sit for a few days to get the seal mashed down. After that, I'll try and open it and see if the silicone helped with the lid being able to pop up enough to slip a finger under the lip to completely open the trunk.
Elmer
Elmer
