Brisk jolt backing C7
My 20016 Z51 intermittently has a brusk jolt when backing. Normally happens when car is cold backing out of garage or parking place. Feels like you are backing over a brick. This happens about one out of ten times the car backs up. Anyone else experienced this?
Received 3,439 Likes
When you put it into gear? Or when you are moving? Is it an automatic or manual? Thanks.
Received 1,738 Likes
St. Jude Donor '15-'16,'18
Does it happen after you wash the car? Could be the pads breaking free of the discs.
As rmorin1249 noted this is often due to one or more brake pads sticking while parked and this can also occur after driving in the rain or due to temperature change and condensation while parked.
if turning, it is common to all of them with cold tires
https://www.corvetteforum.com/forums...-skipping.html
Received 3,289 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
SoCal Events Coordinator
St. Jude Donor '12
Your issue has to do with the extra wide tires, cold temps and turning of the front wheels. All cars with ultra wide tires have this issue, so understand its normal when its cold out, or don't turn so sharply.
Drive the heck out of it and enjoy.
Incorrect...Not all do.
E-Ray, 3LZ, ZER, LIFT
Received 9,623 Likes
It's not the wide sticky tires or the lack of Ackerman steering compensation, it's the high performance tires! Many posters report it goes away when replacing the OEM Michelin's with winter and most all-season tires.
When I got my C7, Z51 in October 2013 the first day it was 40F when I make a full lock turn backing out of my side garage the car started to "hop." Felt like the front end was coming apart! Although GM says it's normal it feels so bad that on those cold days I now make a "K" turns when backing out rather than have it bounce around. When warm I make a full lock turn to head down the driveway without any chatter or hopping!
Easy workaround in the winter to make up up for the super lateral "g" force obtained in the Spring, Summer and Fall. Frankly in Eastern SC most days in the Winter as well!
If the OP wants to know why it happens, this is a 4 page picture/text PDF I made from the research I did: http://netwelding.com/Wheel_Chatter.pdf
