Does Engine Warm-up Hurt or Help?
#41
So here's the thing: warming up an engine is a good thing. But, the best way to warm up an engine is to drive it; gently until your oil/engine temp comes close to specs. Then drive it as you like. Letting a cold engine idle to warm up doesn't really warm it up. Only driving it warms it up. All that idling a cold engine does is let the cold engine run longer before warming up. That's not good. Of course, this is JMO, YMMV.
In the old days with carburetors and mechanical chokes cold idling prolonged the warmup process and would force a rich mixture longer than necessary. Doing that could dilute the oil with gas and cause raw gas to wash the cylinder walls of oil, neither of which is a good thing. The service manual of my C2 warned about that, which they called "crankcase dilution." That's not as much of a factor nowadays as today's EFI systems usually normalize the mixture quickly, so prolonged cold idle wouldn't pose the potential problems now as it might have in the past.
#42
Keep a battery maintainer on it, and leave it be until you intend to drive it again.
#43
Still no word on tolerance
Actually, I don't. I prefer a manual Transmission in my cars. On a boat you have no choice. There are only a few Marine Transmissions (they are called CLUTCHES) available now. With ZF and Twin Disc being the most popular on a conventional setup. The IPS drives that Volvo and Mercruiser uses have their own unique clutches. Back in the day, there were many more but as the industry consolidated they died out. And, like most things today even those Clutches have OPTIONS on them....like Electronic Wireless Shifting and Electronic Trolling Valves.
One last thing.....since we're talking about temps....everyone lives in varying climates....the Length of warm up time will very...here in Northern California my average time is between 5 and 10 minutes ........there are so many makes and models, all with different tolerances, like some of these overseas models.....there is no set standard.....I've got 5 to ten minutes to wait....I want mine to last.....I know.....I know in today's world everybody can't wait.....it's now...now...now.....so there's going to be those who will come up with reasons to NOT WAIT.....thanks for reading....Zappa
#44
The Consigliere
Received 5,444 Likes
Just take it easy with the throttle and rpm until you get some oil temp (140-ish) before you start hammering on it.
If you want to toast a set of valve springs, spin a cold engine to high rpm habitually.
#46
I give it about ten seconds after start up to let the oil circulate and then off we go. Keep the revs down until the yellow tach ring disappears.
#47
#48
I tend to keep at least one of my daily drivers for years and put some decent miles on them. My last SUV was a 2000 Durango and I got rid of it in 2014 with 300,000 miles one it. It ran great but I didn't want to replace the cadilitic converter so I sold it(it got damaged during an off road crash). I have another daily driver, 2007 Jeep Commander with 201,000 miles on it and it also runs great and I plan to keep it for 25 more years. Lol. Anyway, I idle the **** out of all of my cars. So I conclude based on my experience that ideling a car to warm the motor probably doesn't cause much harm. On the other hand driving away slowly provided the outside temp is not extremely cold probably doesn't cause engine damage either.
I'm convinced that there are studies and articles to suggest idling is harmful that are driven mostly from our environmental activist friends.
To me it doesn't pass the BS test and I don't know of any manufacture warranty denials based on excessive idling. We live in a time of fake news people.
Just for fun I'm idling all four of my cars right now.
#51
Interesting topic. I think it's misguided to attempt to make this a one size fits all situations kind of topic since there are several variables that do influence the overall impact. For example, after several weeks of snow and no driving, the oil can be near freezing in temps. If I start it up, and get going right away, only driving three miles, in real low temps, then park the car for two or three hours, then drive it back home, the oil may never get to 100. Several days of that seems not too smart. For those reasons, I tend to warm up the car a bit (I like my oil temp to be around 60 before I get going, and then I still drive it easy. Ultimately, if roads are drivable, then I aim for at least one longer trip amidst the short trips, so I can legitimately get it going, as I'm not a fan of idling a car to warm it up. In general, I don't do it, with DD, nor truck, especially if driving enough to allow it to warm on it's own.
The other side of this is battery life. I'm used to driving my truck much of a day, then parking it outside of hotel, with over night temps around -20. No tender, no oil warmer, etc. and no problem starting up in the morning. Key point, though, is that this is in the context of the truck being driven allot during the day, so the whole truck is thoroughly warmed up, which means even with the cold temps, it's not like a vehicle that has sat several days in those cold temps.
How much a car gets driven is a practical variable in this discussion, as is how long the car has been sitting, IMHO.
#52
You have to love humerus Vette owners
#53
Received 8,926 Likes
You can idle a car for years no matter. Look at trooper cars. They idle all day (northeast mostly) and most police cars are left to idle because of problems on restart (researched by Police). They beat those cars regularly. They go to auction with 200 to 300 thousand miles on them. Taxi drivers pick them up for nothing. All trooper/Police cars are heavy duty with coolers everywhere but still....
Diesel motors in trucks cars idle into eternity with no problems.
Taking off when a car is cold is what kills them because the oil is muddy until temps are up. The oil doesn't spread evenly leaving dry spots.
Gasoline engines do fowl plugs when idling too long though.
The only way to warm the engine quickly is to produce some power output from the engine. Idling only takes a couple of HP to keep the engine rotating and a couple more to power the electrical system. Driving at moderate speeds for the first few miles requires 25 to 30 HP which generates far more heat and greatly hastens warm up.
Bill
#54
No such thing
Oil leaves a lubricating film on the critical parts and the engine can safely be run at moderate power levels until it warms up. Even if what you said is assumed to be true it would still be better to drive the vehicle Vs letting it sit and idle for warm up as the dry spots could cause just as much damage during idle and there would be a greater chance of them occurring.
Bill
Bill
#55
Pores, hahahaha . . .
#56
I know, but you said "pours" and you meant "pores." However, molten metal does pour.
#58
Human
#59
Why does the Corvette tachometer have a yellow and red indicator that is displayed when the engine is cold warning the operator of the dangers of turning higher Rpms on a cold engine? Why would they go to the trouble of adding this warning indicator yet did NOT provide any in car warning for excessive idling of a cold engine? Jeopardy music is now playing. Additionally, manufactures install remote start all the time knowing full well that this feature will result in cold engine idling. The answer. They are not concerned about it causing issues. If idling a cold engine was a concern remote start would not be a factory feature. Environmental activists and left wing media have worked hard to twist information to further their agenda and this is why we even discuss this ridiculous misconception. Can anyone point to any actual warranty claim associated with excessive cold engine idling? On the other hand I know many people that have high mileage trouble free cars that have been warmed up prior to driving since new.
#60
I have been driving away *gently* with cold engines for decades, with all of my cars (yes even those with carburetors), and never once had any issues. I wait until it's nearly full temp before hammering on it. This is a no-brainer. For anyone who's been paying attention at all, I can't believe this is still a topic of conversation.
With race cars or other special applications, there may be good reason to idle up to temp before actually using the motor power. Or, for those who insist on using full power as soon as they get in the car, then yes you should warm it up. Otherwise there is no real benefit.
