Side Skirts help
E-Ray, 3LZ, ZER, LIFT
Received 9,625 Likes
My rocker panels and skirts are 3 years old and look new! I bought them early on because they won a SEMA award and I was having my heavy GM plastic marked by pebbles from those sticky Z51 tires. (I removed that plastic ~6 months after installing when I was sure the LG Motorsports side skirts did the job-they do!) They are also very rugged and will handle the occasional brushing by your passengers (and you) on exit!
Rear Splash Guard Work, Front Not Effective to Protect Rocker Panels- Need Side Skirts.
LG Motorsports CF Side Skirts are Contoured Vertically and Fit is Very Tight
Got my GTX skirts on today. They fit great. I love that they use the oe bolts. I added some 3m auto tape to the rear to really tighten them up without using the included pop rivets.
Bmwmike (02-19-2017)
I have been looking at the different side skirts available for the C7 std and Z51. There are numerous manufacturers and prices. The style that I like best so far is LG Motorsports but the price is more that what I want to spend. Next is ACS Zero 1 Style at approximately $500.00. Other manufacturers are Lashway, C7 Carbon, and number of other names that escape me know.
I like the way the ACS fit the body. Some of the other brands are flat and just bolt to the under side of the body. I wish the ACS would extend out further like the LG. My thinking is that would be more efficient stopping the stones from hitting the side of the body. Does anyone know of another manufacturer making side skirts like LG, but at a more reasonable price.
I looked on Amazon and found side skirts similar to ACS at lower price. The manufacturer is ???. Just looked at Amazon and now can't find the company, but the price was $299.00. My question is does anyone know the company and what is the quality of their product.
Any help or suggestions in this area is helpful. Thank you a head of time.
Understand that drilling on a new car is a concern for many. However when installing side skirts they are placed in position using OEM bolts at the ends. Therefore you’re drilling very small holes and only into the SMC rocker panel NOT the frame when they are already in position.
The SMC drills like butter. I used small aluminum rivets requiring very small holes. An inexpensive hand rivet gun is all that is needed.
Recall a poster who had used 3M tape reply after seeing how tight mine were attached using rivets to get them to get his to fit tight. When he or a passenger bruses against them when exiting (inevitable) it's also a more secure attachment. FWIW
LG Motorsports CF Side Skirts are Contoured Vertically and Fit is Tight
An inexpensive hand rivet gun is all that is required. I used a stainless fender washer under small aluminum rivets to to spread the load.
There is a small gap between the rocker panel and the aluminum frame. I inserted a scrap piece of metal in the gap when I drilled so I didn't hit the frame. Although, as recommended, I moved the rivet to the outside to have a tight fit (which I do) it is still at the bottom of the rocker panel.
Rebel Yell (07-03-2017)
Thank you
Just want to thank everyone for their input and pictures. Need to save a few more dollars and then make up my mind as to which ones to order. They all look real good. Like the idea of being able to remove the factory rear clear plastic protectors.
PapaLeo67 (02-20-2017)
Sorry to go off topic, but what are these factory rear clear plastic protectors you speak of??? I just noticed that none of the pics above have that ugly thing that I have on my all AW that looks like its turning yellow.
Are you talking about this? And they come off?
Wait... What???
#33
C7 Carbon make great products... Have had them on my GS (splitter and skirts), on the wife's '14 (splitter), and on my '16 (splitter and skirts):
I wanted something unusual for the wife's skirts, so I ran across the Stingray skirts while looking at alternatives and installed them:
PapaLeo67 (02-21-2017)
#34
Does anyone know what they are called? I cant seem to find it on google.
#35
Well, Im really happy that they come off. They are so thick, I thought they were actual body parts. Thats the one thing I really hate about my car, because they are getting discolored. I didnt even notice them when I bought the car... Now its the first thing I see.
Now I cant wait to get them off and get my skirts
#36
This is a picture PDF of how I removed mine. It shows what to do AND what NOT to do.
http://netwelding.com/Rocker_Panel_Film.pdf
Fortunately I only had a problem in a small section along the bottom by pulling it off at the wrong angle. That ~6 inch section took ~30 minutes to remove the adhesive! Do it right and pull at the right angle!
