Z51 without PTM
Naples FL
Z51 without PTM
Is competitive mode the equivalent to Sport 1, Sport 2 or Race?
Good question!! I don't know - I have a Z06 with MSRC and PTM. I suspect Comp mode in your Z51 comes close to what those of us with MSRC get when we go into the non-PTM Track mode.
When the **** on a PTM car is turned to the Track mode, without pushing the button twice, it's in some sort of Comp mode - and exactly what mode each of the systems is in when you're in that non-PTM Track mode isn't definitively defined, at least not that I've been able to find.
Take a look at this thread:
https://www.corvetteforum.com/forums...rack-mode.html
That thread is all about PTM, but in that first post you can see the table below:
In that table you can see the various systems that act differently as you progress through the PTM modes. You have all those systems except for the magnetic shocks, and of course your eLSD won't be in the PTM mode when you're in Comp.
You can see that in Sport 1: TC is in Sport; Active Handling is in Comp; Steering is in Track.
When in PTM, the TC in Sport means something entirely different than your TC. The PTM TC is "predictive" in order to stop wheel spin before it occurs, whereas your TC simply "reacts" to stop wheel spin after it already has happened. So, I don't really know what Comp mode does to your TC. When you select Comp mode AH is not as intrusive - it lets the car go a little farther before it puts in AH corrections. In Comp mode your TC may doing something similar to that.
I suspect that Sport 1 is about what you'll have when you go into Comp mode on your Z51 without MSRC shocks - but I'm just sorta making an educated guess without having been able to find out even what we have in a PTM car when we go into Track mode without doing the double button push to enter the PTM mode.
Bottom line - your Comp mode is probably very much like the base Track mode of a PTM car (select Track without pushing the button twice to go into PTM mode), and is probably very close to Sport 1 except you have regular TC and not PTM.
I'll be watching to see if anyone has more specifics about it!!
vbdenny (02-23-2017)
Naples FL
I just did Spring Mt last Thurs/Fri, and I asked them about the base Track mode (select Track but don't double push the button to go into PTM). They waffled because they just didn't know the specifics. As I mentioned in my other post, I haven't been able to find any specifics on exactly what you've got in that mode - and it's probably very similar to Comp in your car.
You say "only way with PTM To get full power is race mode".
Well....you're only slightly limited during track-out when the steering wheel isn't completely unwound, and you don't need full power then anyway - the engine will give you all the power that the contact patch can handle for the mode selected. As soon as you've unwound the wheel you'll get FULL power.
I think with your car you can turn EVERYTHING off by pushing and holding the button for about 8-10 seconds. You can do that with a PTM car as well. In either car you'll get FULL power all the time in that case.
Naples FL
Yes - they're different!! The TC in Sport 1 is controlled by PTM, where the TC in Comp is off (or possibly allows a little more wheel spin before intervening).
Naples FL
In Z51's without PTM, the Competitive Driving Mode turns off Traction Control and switches to a less intrusive Competitive Stability Control mode than the normal Stability Control mode. Therefore the Competitive Driving Mode has a different Traction Control setting (completely off) than all five PTM modes and a Competitive Stability Control mode equivalent to that of the PTM's Dry and Sport 1 modes.
Traction Control applies the brakes and reduces engine power. Stability Control applies the brakes and does not reduce engine power.
Take a look at the video below - in you can see that just above the RPM display it initially says "Performance Traction Management: Sport 1". At about 1:07 into the video you can see a little wiggle of the rear end, and a couple seconds later the "PTM: Sport 1" disappears.
I figured it went into the "basic" Track mode (non-PTM Track mode), which I believe is somewhere between Sport and PTM Sport 1 (probably somewhat like Comp in your car).
You can see after PTM Sport 1 drops out, there are numerous times where I got that "skidding car" icon just to the left of the lap time. I get it braking straight ahead, and also in turns - but AH wasn't intrusive at all, and I couldn't feel any AH input. I have previously run my two C6 Vettes on the track many times, and usually in Comp mode, and I could always feel little tugs and see "Active Handling" in the DIC whenever AH was doing its thing in those cars.
I've only run my C7 at 3 track events so far, and all have been in Sport 1 (except for that session in the video where it dropped out), and I haven't felt any AH intrusion.
At Spring Mt last week in the wet figure-8 exercise, when PTM Wet mode was selected the AH was VERY aggressive!!!!! So I'm quite sure that when Sport 1 dropped out on me in that video, and it went into what I assume is the basic non-PTM Track mode, it definitely was not in the Wet mode!
My next track event is in 6 weeks, and I'll be back at my home track - the Rolex 24 roadcourse at Daytona. I'll try to remember to try out the basic non-PTM Track mode to see if does any real aggressive AH inputs like it would in the Wet mode.
Naples FL
Somebody told me that in another thread, but I haven't tried it out. They said that TC and AH were VERY intrusive in the basic Track mode!!
Take a look at the video below - in you can see that just above the RPM display it initially says "Performance Traction Management: Sport 1". At about 1:07 into the viehenni did that exerciseondeo you can see a little wiggle of the rear end, and a couple seconds later the "PTM: Sport 1" disappears.
At Spring Mt last week in the wet figure-8 exercise, when PTM Wet mode was selected the AH was VERY aggressive!!!!! So I'm quite sure that when Sport 1 dropped out on me in that video, and it went into what I assume is the basic non-PTM Track mode, it definitely was not in the Wet mode!"nono:
https://youtu.be/io92rgb-frY
i really believe that the default for track mode is "wet track" because you are right; the "nannies" are very intrusive in just track mode with out PTM engaged. Also, when you engage it; it's in Track wet immediately
