Pothole 1, Chinese wheel 0.
Drove to NoVA last week and got off of I-66 at the Falls Church exit 69 and squarely connected with a pothole on the ramp. Took out my front right wheel. Surprisingly, the tire remained seated and did not lose air. These were cheap Chinese knockoffs that I run in the winter with A/S runflats. Will be interesting to see if I can buy a single matching replacement.
Received 4,505 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Bummer!
Originally Posted by Boucherman
I'm no expert, BUT I do believe that that wheel could be repaired. Might be the cheapest and best solution.
Received 2,225 Likes
Would most tire shops be able to do a repair?
No, google "wheel repair".
I have a wheel shop that has repaired a couple of wheels (not Corvette
) for me due to Detroit area potholes. I saw wheels much worse than this in the shop to be repaired.
Heat that baby up and smack the Chinese out of it
The following 7 users liked this post by bbrown450:
B-STOCK (03-11-2017),
egp (03-11-2017),
joemosfet (03-11-2017),
matt3310 (03-13-2017),
Rebel Yell (03-11-2017),
and 2 others liked this post.
Received 1,738 Likes
St. Jude Donor '15-'16,'18
The runflats have such stiff sidewalls that a lot of the energy is transferred to the rim and this is the result. There is a good wheel repair place in MD over in the Laurel area, I think. You may well be able to have it repaired. Good luck.
Here you go: http://www.yeolewheelshop.net/
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Received 2,239 Likes
It may indeed be repairable, but since it *is* a cheap knockoff, and depending on repair cost, *might* be better to replace.
IDK what such a repair would cost, but for example -- personally I'd feel better spending $200 for a new wheel than $100 for a badly bent & "repaired" one, where the resulting structural integrity would always be nagging at my mind.
Your right but I have had many. What happens (ME) the whole rim takes a hit like a car does. I find it's never right but you guys are the experts.
Gonzo (03-11-2017)
Gonzo (03-11-2017)
