Paint cure before clay bar and wax?
I took museum delivery of mine and immediately transported in an enclosed trailer to my detailer. Everyone can believe what they wish, but mine needed the clay bar in advance of the paint correction then Expel Ultimate application. I then had Opti Pro applied to the whole car and wheels. I also took my new truck and had the same treatment performed minus the Expel. My new Z06 will get the same treatment. The Clay bar is a cheap process that adds to the smoothness of the finish.
I'm decontaminating mine as soon as it gets home and also will not allow the dealer to wash it before delivery.
1.Wash w/foam gun and two bucket method
2. spray with iron x
3. Rinse
4. Wash with nanoskin kit
5. correct any scratches
6. Wolfgang prep spray
7. Ceramic coat
Bought a new fine nanoskin kit from amazon and the rest from auto geek. My paint is going to be marvelous!
3. Rinse
7. Ceramic coat
Unless there's some sort of foreign grit bonded to your new car's finish - all you need do is wash with water fortified with a neutral detergent concentrate, rinse, dry, then apply a polish finish to the surfaces. I use Wizards Mist N Shine spray. That's it. Wizards products are non-petrochems, so you're not having to breathe those harmful to the respiratory system petro-vapors, while applying their products.
you can use any polish on new paint. do not seal or apply wax for at least 2 weeks.
for those who believe factory paint is hardened as soon as it leaves the plant? why do you think this? like the scene from my cousin vinny "do grits cook faster in your house than everywhere else?"
it's still outgassing and curing like anywhere else. whether or not it does any harm? who knows but those instructions were told to me after having an expensive paint job done and the guy who did it laughed when i mentioned "not like a factory paint job huh?
Good luck OP.. you could wash it with an iron X type wash and polish your heart away for about a month. why take a risk? is it worth it?
I recently had the owner of a high-end body shop tell me that waiting 60-90 days is a smart thing to do. He said that though modern paints "cure" very quickly, there is still some "outgassing" as part of the curing process, and that further hardening does occur for a couple months after new paint.
It's probably a minor difference, but I've always waited at least 3 months after a build date before doing anything other than a light polish.
