How do you remove shift knob?
How do you remove shift ****?
I tried unscrewing the shift ****, but it is really tight and I dont want to damage it if it doesn't unscrew.
Any one know how to remove it???
carfully remove trim ring turning counter clockwise and pull down.
remove retaining screw.
remove ****.
per gm service info.
trim ring is just under shift ****
remove ****.
Removal Procedure
1. Carefully remove the shift control **** trim ring (1) by turning counter-clockwise and pulling downward.
2. Remove the shift control **** retaining screw (2).
3. Remove the shift control **** (3).
this is what service information says.
i think trim ring only turns @ 1/4 turn then should be able to slide it down and access retaining screw
This trim ring I turn CounterCW, it is at the top of the
shifter leather boot right?? It does not turn 1/4 turn
since it is attached to the boot.
The shifter leather boot is pressed inside the ring at the top next to the ****. when trying to turn the ring c-c-w, the boot holds the ring and the ring can't be turned as is.
do I need to pull the leather boot out of the ring first??
the info in post 5 is all that si says. I don't think you pull boot out of ring.
if you want to pm me your number I could text the pic it shows but it is just
cheap engineering pic ?
If you center the stick, there should be enough flexibility in the boot to turn the ring 1/4 turn.
Worst case, you could take the bottom of the boot out of the console..
The ring should be the same as newer C6.
