Sneak peak at Vararam C7 CAI
#41
The systems for the C5 & C6 took cold air directly from the front of the car; great air flow and a material difference in reducing the air intake temperature. I picked up almost three tenths at the track.
The amount of cool air from the bottom of the fender well on the C7 is most likely not that material. You can probably home brew a plastic connector tube and insulate it to keep it somewhat cool. But you will have to cut up the inner fender & grill to get cold air .....give it some time and someone will home brew a cold air syatem
#42
#43
Can you actually feel the difference with just the AFT cai?? I know they claim around 18 horse/22 torque which is a great amount for a cai....just curious if you can feel the difference between stock.
#46
Just me thinking that you can get cold air if you install "home brew" ductwork from the filter to the grill. Early on in the C6 generation our members propped the shroud & etc. to get cold air.
The C7 is a bit more difficult as the filter is on the side and not in the front. While installing my Z06 grill I drove around with the nose off and hp tuners. The air intake temperatures dropped by 10 degrees.
Just imagine what some ductwork routing the cold air directly to the filter would do. That is possibly why we have not seen a Vararam intake system, as it would have to seal to the filter box.
#47
I called Vararam today they said they had two prototypes and had not decided which way to go yet. No time frame for a release.
#48
Sneak peak at a vapor product in production for almost 2 years? Pass.
I know some will disagree with me but I don't think the aftermarket CAI's for the C7 are worth the price. Unless you just like looking at your air filter
#50
