WORLDS FIRST 9 second C7!!!
#42
This car with those mods should be well into the low 9's at 137mph+. Does that cam retain the vvt/afm or is still a "standard" grind?
Sounds roudy and the car runs great on motor.... any approx. power numbers you can share before an official release?
5xxrwhp ??
#45
Supporting Vendor
Your not kidding...that poor converter was begging for mercy.
5xxrwhp ??
5xxrwhp ??
#52
Great accomplishment! LMR nails it again.
How is the transmission holding up with that kind of torque multiplication? What are your tranny fluid temps like in daily driving with a high-stall like that?
Any signs that the tranny is about to let go after a few hard passes at the strip on sticky tires?
If this tranny can reliably handle close to 700 RWHP from the factory, then I've just died and gone to heaven!
#53
sweet……..buy the sound of everyones footsteps I could tell there was some serious traction compound put down !
#54
Supporting Vendor
#58
Scraping the splitter.
140 (on the high end) in the 1/4 on a 1.40 short time is nowhere near an 8-second pass. I've run similar increments a few years ago in a car with a TH400, and they were 9.6-.7 passes.
S.
#59
Supporting Vendor
While I agree that based on the 1/8th speed, the car should have trapped ~138-140 in the 1/4, IMO there is no way that would account for "close to a second".
S.
S.
