Fuel Rail and Plenum Cover Removal
Old 03-28-2014, 10:37 PM
Pete@Showstopper
Supporting Vendor
Pete@Showstopper's Avatar
St. Jude Donor '14. '17
Originally Posted by snakepit
Where did you get the stingray fuel rail covers from.
Here ya go.
http://showstopperaccessories.com/pr...il-Covers.html
__________________
www.showstopperaccessories.net
Old 06-21-2014, 08:30 AM
Thepiazza
Thepiazza's Avatar
Peter thanks for the info! Now it's time to get these bad boys installed.
Old 06-28-2014, 08:42 AM
Pete@Showstopper
Supporting Vendor
Turned out great.
Old 08-13-2014, 09:51 PM
SevenTurns
Support Corvetteforum!
SevenTurns's Avatar
St. Jude Donor '13-'14-'15-'16
Pete,
These look great!
Thanks,
Jim
Old 08-14-2014, 08:15 AM
Pete@Showstopper
Supporting Vendor
Looks good. Flows nicely
Old 08-16-2014, 10:04 PM
Pete@Showstopper
Supporting Vendor
Blade silver
Old 08-09-2015, 08:10 AM
MJZ
MJZ's Avatar
St. Jude Donor '15
installed yesterday.
Old 08-10-2015, 11:41 AM
MJZ
MJZ's Avatar
St. Jude Donor '15
What ya thunk?
Raidercop (09-19-2021)
Old 08-10-2015, 11:30 PM
Pete@Showstopper
Supporting Vendor
Default Fuel Rail and Plenum Cover Removal
Looks like the install went good.
Old 06-05-2016, 09:22 PM
PapaLeo67
PapaLeo67's Avatar
So, What is involved in transferring the wire harness into the new plenum?
Anyone have coil cover removal instructions available?
Old 06-05-2016, 11:36 PM
Rooster OG
Rooster OG's Avatar
Received 1,694 Likes on 1,240 Posts
St. Jude Donor '15
There's no harness to transfer. There are a few things to unplug, then if you're doing the lower covers you have to cut the zip ties holding the plug wires. It's easy unless you have a z51 with that one damn vacuum hose going through the lower passenger side cover. Thats a little tricky. It's all really apparent when you're looking at it.
Old 06-27-2016, 08:18 AM
Pete@Showstopper
Supporting Vendor
I'm glad this thread has been helping out people
Old 07-10-2016, 07:40 PM
  #33
PapaLeo67
PapaLeo67's Avatar
Snapped a couple zip tie holders on the plenum
That plug is busting my ***** too... Cant wait to get to the z51 vacuum line.
Old 07-10-2016, 08:37 PM
  #34
BJ67
BJ67's Avatar
Originally Posted by louloumax
stupid question:
does removing the covers affect how the engine runs? seems like it would run cooler w/o them.
I have all the plastic covers off along with the insulation under the plastic intake cover, intake is cooler.
Old 07-10-2016, 09:37 PM
  #35
PapaLeo67
PapaLeo67's Avatar
OK, Need a little help/advice.
I took off my plenum, fuel rails, and coil covers...
I Need to find the name or part number for the zip tie anchors that hold the wire harness to the fuel rails. I broke half of them. They did not "wiggle" out as suggested. In retrospect, I bet it would have been easier with a warm engine. Maybe they would have been softer.
Also... like many others, I broke the edge off one of the little wings on the Z51 line that goes into the coil cover on the passenger side that everyone complains about. It was just the edge, maybe 1mm, but enough to **** me off. Again, Im sure a warm engine would have made it easier. I saw that part number before, but I cant find it now.
Questions:
What is that line for? What is its function? It was a little oily when it came out. Also, Im asking because I forgot to put it back on and I took a little spin around the block to make sure everything was running good. No Problems at all. I put it back in, and drove again... no difference.
Also, the screws I had to remove to take out the coil covers do not come out of the covers. I was afraid I was going to drop one so I had a magnet on it while turning. It would have been cool to know they wont fall out ahead of time. Should they be forced out somehow before they are painted? If so... HOW?
Thanks in advance.. If anyone wants to do this, its pretty easy, but I highly recommend a warm motor.
Old 10-16-2016, 10:25 PM
  #36
syswayne
syswayne's Avatar
Default Lower covers
Originally Posted by Pete@Showstopper
We have had quite a few of our customers request instructions for removing the fuel rail covers and plenum cover after purchasing our smoothie versions. Here is a quick session on how to do so.
Plenum Cover
http://showstopperaccessories.com/pr...num-Cover.html
Fuel Rail Covers
The fuel rail covers are just snapped in place using a rubber grommet style fastener. Start of by lifting upward more towards the plenum side and they will unsnap without using too much force.
Then, once you remove the fuel rail you will notice a wiring harness that is fastened to the plenum cover. They are just zip ties that are snapped into the plenum. So if you wiggle the zip tie upward, it should slowly come out. Sometimes a tool is needed to get this started. This is what it should look like once removed.
The next step is to remove a total of four 10mm bolts that hold the plenum in place. These also have a nipple at the top in which your fuel rails snapped into.
Lastly, there is one wiring connector that will need to be disconnected in order to lift the plenum off. Once this is done, you are ready to lift the plenum off.
Reverse the steps to re install everything. If you have any questions, feel free to pm me.
The lower covers are bolted on do you know how to remove the and can the be removed for painting. I did the other 2 and they were easy, but this one looks pretty hard for me at 77, but I have worked on many cars and this C72016 I just purchased. Please advise, syswayne
Old 10-16-2016, 10:28 PM
  #37
syswayne
syswayne's Avatar
Plenum Cover
Fuel Rail Covers
I did the other 2 and look great, but how do I remove the lower covers that are bolted on and can they be removed for painting. Please advise and thanks for all the information. syswayne
To Fuel Rail and Plenum Cover Removal
Old 10-17-2016, 09:50 PM
  #38
Pete@Showstopper
Supporting Vendor
You have to disconnect the breather lines,then just remove the two bolts holding them in place.
Old 03-28-2017, 10:40 PM
  #39
semperfi1946
semperfi1946's Avatar
Default Plenum cover removal
How do you get the 4 zip tie connectors to release from the plenum cover ?
I have pulled on them and they will not come out. They look like serrated plastic fasteners.
Old 03-29-2017, 12:05 AM
  #40
semperfi1946
How do you get the zip tie fasteners to come out? I have pulled on them HARD and they do not come out - they look like serrated panel fasteners - do you need to use a panel fastener tool to get them out to replace the plenum?
Quick Reply: Fuel Rail and Plenum Cover Removal
