Texas Speed Heads Cam LT1 Engine Dyno Video
Jason I may be interested in doing a head swap when I put on the TSP Long Tubes and X pipe I ordered (btw the exhaust system looks AWESOME).
Factory Compression is 11.5 (58-59cc???) how much milling can be done to raise compression before there is intake to head problems, 12.0?????
This engine uses TTY M12 head bolts and they can be bought for roughly 30 bucks and the 7 layer head gaskets are priced right too at around $43 a piece.
I don't want to do a cam, just be nice to have a 360cfm head on the car for $900, GREAT DEAL btw.
What kind of RWHP numbers are you looking for with just a head swap and long tubes. This sound like this might be interesting. I really dread pulling the front of the engine off for the cam swap.
TSP LT's X-pipe $901 shipped (special intro price)
TSP PRC LT1 heads through Exchange probably $1000 once shipped
E85 flex fuel conversion $300
Tune through HPTuners (tuner by trade) $90 for credits
Head gaskets $87
TTY bolts $35
Green Air Filter $115 shipped (I do fabrication on the side and may build a CAI system using a 7inch bellmouth opening with a larger filter)
Through an A8 I would guess around 470rwhp and 485 through M7
cost is roughly $2600 with a few misc parts/fluids and a car making roughly 70rwhp more than stock with perfect drivability.
Cam swaps on the C7 are a little trickery and time consuming, I don't consider it a big deal to swap heads though.
I really like that your testing everything you sell on an engine dyno and perfecting the recipe. I will definitely be talking to you guys soon as I plan on doing a head cam swap in my car, to build a road course monster.
Premium Supporting Vendor
Crate engines are easy. We have already made just under 700hp with a LT1 stroker 416. I have a 427 short-block here now
Jason
Jason
* Headers
* Superchargers (think basic kits.. not the OFF ROAD USE ONLY units)
* Turbochargers (again, same applies.. basic kits)
* CAI
* Intake manifolds (like the basic offering from MSD)
When I've inquired into the use of camshafts and aftermarket heads, I get a WIDE variety of answers (obviously because of all the different combinations). I've asked about CNC ported stock heads and it seems that no one wants to give me a straight answer. Many DO say something to the effect of "it SHOULD pass" or "it would more than likely pass." Camshafts are the same way. They really wake the C7 up but for us peeps in emission controlled areas, it's a roll of the dice.
So, to anyone out there who has a good working knowledge of the C7 as it relates to emissions, can I install a "mild" set of heads (or CNC ported stock heads), a "mild" blower cam in addition to the upgrades that I've already planned for my C7: ECS Supercharger, LT Headers and an ECS meth kit.
There is no sense in spending thousands of dollars on higher HP numbers, only to be told during my state emissions testing that I failed and cannot get my state inspection. I've got the money just burning a hole in my pocket.. haha! But, it seems no one wants to give a definitive YES or NO on the setup listed above or even a combo of the items listed above such as:
Headers, Supercharger, CNC ported stock heads: YES
Headers, Supercharger, Camshaft: NO
Etc.. etc.. etc..
Well, that's exactly what I'm finding out on my C7. TONS of potential for high HP on these cars. I would LOVE an 800 rwhp beast.. but for those who live in areas who have a state inspection that requires the use of a "sniffer" to pass the emissions portion of the state inspection, I am greatly limited to keeping my HP upgrades in check. After talking to TONS of locals here in the Dallas / Fort Worth area in Texas, I am overwhelmingly assured that the following "upgrades" will still allow a car to pass the emissions "sniffer" test:
* Headers
* CAI
Etc.. etc.. etc..
* Headers
* CAI
Etc.. etc.. etc..
My suggestion is you get a standard blower kit, meth injection and some long tubes with cats and keep future upgrades in mind.
You can easily get 650whp from that combo. You can get 700whp from that combo too if you want to push it with more boost (ECS is the most easily upgradable kit for this).
Get a non-meth tune at lower hp to run during the emissions testing. You'll still make 580+whp. I don't honestly know if having a tune using methanol will fail your emissions or not.
A SOLID 700 rwhp is my target on my A6 Z51. Anything approaching 800hp, I fully understand the need for forged internals.. so 700hp on the ground should be pushing it but still in the "safe" realm. I'm wondering if the ECS supercharger (restrictor plate removed), meth kit, long tube headers + MSD intake manifold + CNC ported stock heads will be enough for a true 700 rwhp in my A6 (and be able to still pass my emissions test)
Anyone else in the Houston or DFW metro areas know for sure?
Guess I'll go visit my old buddy Google and see what he comes up with.
Correct me if I'm wrong, but the counties in Texas that check emissions (including Harris, where I have to get my inspections) simply plug in your OBDII port and check for emission related codes, as well as visually inspect for emissions equipment presence. Sniffing went away years ago. At least this is what I recall when getting vehicles inspected.
#33
#34
http://www.dmv.org/tx-texas/smog-check.php
http://www.txdps.state.tx.us/rsd/vi/.../faq_obdii.htm
#35
Excellent! I understand about the ECU throwing codes that may fail me so like it was mentioned in the other post, have a tune for everyday driving and have a separate tune for my emissions testing.
#36
Jason, can breakdown the following costs,
Vvt dod delete plus 32 fuel lobe parts and install cost
Short block with the above cam
Forged short block with above cam
#37
This brings up a good point. With the cam install costs on these motors it very well could bring a short block with a blower cam into play.
#38
* Thread revived *
I finally ended up getting my supercharger installed a few months ago along with ARH long tubes, ECS Alky Meth, LMR breather and a tune. My final numbers are 662 rwhp / 585 tq. Today, I drove to another tuner today and we discussed some TSP CNC'd factory heads and their VVT-1 camshaft (with forged / hardened internals) and a retune. I'm told 100 extra ponies can be had on top of my current power levels. Do any other C7 owners have any experience with this type of setup?
ECS 1500 (unrestricted) supercharger
ECS Alky Meth Control - 100% VP M1 Methanol
American Racing 1 7/8" Long Tube Headers (with cats)
LMR Breather
TSP CNC heads
TSP VVT-1 Camshaft
I'd like to hear any feedback that you might have.
LMR Breather
TSP CNC heads
TSP VVT-1 Camshaft
#39
* Thread revived *
LMR Breather
TSP CNC heads
TSP VVT-1 Camshaft
LMR Breather
TSP CNC heads
TSP VVT-1 Camshaft
#40
To officermartinez. I think 80-100 to the tire would be seen with a good heads and cam combo.
What are your goals though? Is 700 to the tire your goal? If it is just pulley down for a little more boost and maybe do a cam to get a little more fuel out of it. You could get to 700 with a cam swap easy with your 10 psi and meth. My car made 660 with 7 psi, cam, headers, and meth. Would be well over 700 if I removed the restrictor and did 10 psi and I think your car would too.
