How do you route the battery maintainer?
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
St. Jude Donor '14-'15
These are the spots that can be used for jumping. According to the schematics, it's a straight path to the battery without any relays to switch the connection off mid-path.
Could be a hassle for some folks...I believe the area where my previous house was built required all outside (including garage) outlets to be GFI.
Theta,
if I may draw upon your expertise again, please....
The Positive terminal you describe, with the flip-up cover/lid...
I see it, but I cannot flip that cover up.
It appears to have a little "lock" tab on the right (passenger) side,
and it appears to have hinges on the left (driver) side, where I suppose it hinges from.
But I cannot figure out how to release that "lock" so the lid will swing up.
And I don't want to do much prying, and break any plastic "bits".
Any suggestions, please... and thanks.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,821 Likes
2015 C7 of the Year Finalist
I see this has resurfaced. My plan to reuse my C6 charger for the C7 has become fact. I use a magnetic connector that is located on my front grill to hook up the C-Tek. Here is a thread on the details of how I did it.
http://www.ls2.com/forums/showthread...ery-topped-off
This is the link to the forum sponsor that supplied me with the parts.
https://www.corvetteforum.com/forums...ry-tender.html
Elmer
Elmer
Theta,
Elmer
eboggs,
yes, I know about the handle... it swings up easily.
It is the little cover/lid over the positive wire/post which I am referring to.
However, this morning, I tried again.... it took a little work, but I was able to
finally get it to "pop" loose, and then swing (hinge) open.
So I have now fastened the 2 (positive and negative) wires of my Battery Minder
to the 2 leads/terminals as shown in the photos by Theta.
I don't want to use the trunk cigarette connector... I want to use this
under the hood connection instead.
All is good.
All is good.
#33
eboggs,
All is good.
All is good.
Elmer
#35
This works great for me also. No problems at all with mashing the wires or weatherstripping. Yes, half-closing the hatch will leave the hatch interior lights on ... but only for about 10 minutes, then the C7's automatic timer will shut them off. Seems much simpler and easier than going to all the work to add connectors to the underhood wiring.
#36
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
#37
My 2008 Zo6 can drain the battery. But the ZR1 and the 2014 Stingray have no worries. I can go months and they will start. I have gone 6-8 years on stock battery's. For me I don't find much value from using a maintianer.
The C7 doesn't seem to have an issue like some C6's did.
