C7 Corvette Billy Boat Exhaust
Former Vendor
St. Jude Donor '13
Corvette C7 Billy Boat PRT Exhaust
The Billy Boat Performance Exhaust PRT C7 exhaust system is the latest in resonance control technology, completey redesigned and reengineered for the C7. You can now have a mellow, no-drone sound at cruising speeds and a crisp, clean, noticeable sport note when you're tearing up the streets
Dyno-proven horsepower and torque gains
Deep, aggressive exhaust note
Precision hand fabricated from CNC mandrel bent T304 stainless steel and TIG welded
Maintains the factory butterfly valve and 4-cylinder mode function
Made in the USA
Choice of Tips
4.5" Quad Oval
4" Quad Round
Speedway Tip
Made in the USA
Choice of Tips
4.5" Quad Oval
4" Quad Round
Speedway Tip
Reward Points169 points will be rewarded to you when you buy this item.
Corvette C7 Billy Boat Fusion Bi-Modal Exhaust
Corvette C7 Fusion Bi-Modal Exhaust
We use our experience in bi-modal muffler design to further enhance the factory system
Fusion provides a deeper, richer and more voluminous sound than the OEM NPP system
Mufflers incorporate two passages through which exhaust can travel. A butterfly valve, built into the mufflers, regulates which passage is used.
Passage One is a muffled and chambered tube incorporating Billy Boat's exclusive PRT (Purge Resonance Technology) to eliminate drone at cruising speeds, while delivering deep and smooth American V8 muscle car sound
Passage two is a straight through tube that increases the sound volume to adrenaline pumping levels, as well as increases horsepower and torque
Fusion can be simply incorporated with the OEM C7 NPP system controls
Proprietary 3" butterfly valve system available (OEM uses 2.5" valves
3" pipe diameter
Manufactured to precise standards using T-304 stainless steel and TIG welding techniques
4" round,
4.5" oval double walled tips
Speedway tips
Limited Lifetime Warranty against rust, corrosion or burn through Made in the USA
C7 Gen. 3 Fusion Quad Oval
C7 Gen. 3 Fusion Quad Round
C7 Gen. 3 Fusion Speedway Twin
http://www.xplosiveperformance.com/C...st_p_3621.html
Reward Points245 points will be rewarded to you when you buy this item.
3" pipe diameter
4" round,
Speedway tips
Corvette C7 Bullet
Since 1997 the Billy Boat Bullet Corvette exhaust has been the standard for deep, aggressive muscle car sound for you Corvette, and we have done it again for the C7. If that aggressive note is music to your ears, the Bullet is the only exhaust you need.
Deep, aggressive muscle car note
3" pipe diameter
Uses a B&B 3" buttlerfly valve for inproved flow and performance
Maintains the factory technology for 4 cylinder mode
Made in the USA
C7 3" Bullet 4.5" Quad Oval
C7 3" Bullet 4" Quad Round
C7 3" Bullet Speedway Tip
3" pipe diameter
Made in the USA
Reward Points 169 points will be rewarded to you when you buy this item.
Wow, those prices makes the OEM NPP system seem like a bargain.
Some questions on the Bi-Modal system:
- Does it use the NPP electrical actuators?
- If not, does it include new actuators?
- Can it be fitted to non NPP cars?
Former Vendor
St. Jude Donor '13
For Orders placed between now and the Dec 31
use coupon code BBC7 at checkout get
an additional 13% savings
and still earn your reward points.
Made in the USA
Choice of Tips
4.5" Quad Oval
4" Quad Round
Speedway Tip
Made in the USA
Choice of Tips
4.5" Quad Oval
4" Quad Round
Speedway Tip
3" pipe diameter
4" round,
Speedway tips
Corvette C7 Bullet
3" pipe diameter
Made in the USA
http://www.xplosiveperformance.com/C...et_p_3622.html
Received 1,974 Likes
I have had three B&B systems so far (for BMWs). Love them. LOVE them!
However, there is a limit to my love and a point where I feel like I am in an 80's Jodi Foster movie.
Former Vendor
St. Jude Donor '13
EARN YOUR REWARD POINTS FOR FUTURE PURCHASES EARN $1.00 for every $10.00 Spent
ORDER ON LINE AND SCHEDULE YOUR INSTALL
Join us on Facebook
Join us on Facebook
Former Vendor
St. Jude Donor '13
Join us on Facebook
Join us on Facebook
Platinum Supporting Vendor
