Vengeance Racing C7 | 739RWHP/739RWTQ |Currently the most powerful C7 in the world!
Former Vendor
I tip my hat to Nitro Dave and his crew @ Nitrous Outlet for producing yet another high quality nitrous system!! We have been a loyal Nitrous Outlet dealer for many years and we are always impressed with what Dave delivers. Quality/Fitment/Performance always exceed our expectations. To be quite honest Dave has such an outstanding product and reputation that certain competing nitrous companies have to GIVE their product to shops to get them to use their systems.
For anyone not familiar with our current modifications...
Next up was the Nitrous Outlet Plate Kit. Knowing fuel supply could be an issue we decided to go with a Nitrous Outlet dedicated fuel cell as well.
Our complete kit consists of:
Nitrous Outlet C7 Specific Plate Kit
Nitrous Outlet Stage III Accessory Pack
Nitrous Outlet Dedicated Fuel Cell
NOS Launcher- Fully Programmable progressive controller
All of these items can be found on our online store if interested.
www.VengeanceRacing.net
Here are a few pics of the system installed on our C7. We actually removed the gauge attached to the fuel solenoid after setting fuel pressure and tuning on the dyno for a cleaner look.
The dedicated fits perfectly into the driver/rear storage compartment for a stealth install
Knowing that tuning the new Gen V LT1 was going to be different than previous Gen III/Gen IV LS engines/ECUs we started with a small shot and worked our way up...
35 Nitrous Jet and 18 Fuel Jet
112RWHP/136RWTQ gain
After reading plugs and reviewing the datalog we stepped up to a 52 Nitrous jet and a 28 fuel jet
169RWHP/197RWTQ gain
We made a few pulls dialing in the set up above then read plugs and switched to 62 nitrous jet and a 33 fuel jet.
226RWHP/290RWTQ gains
At this point we are out of tuning capability with the ECU. If we get an update from EFI Live or HP Tuner before our blower gets here we will jet up once more to crack 800RWHP ( or a piston, whichever comes first)
Here is a short dyno video on the 62/33 jets
We will get to the track as soon as we can get some decent weather. Monday it was -3* and today its 40* and pouring rain.....
Stay tuned for more results as we continue to push the envelope on our C7. Next up we are installing an ECS system and meth kit. To keep things interesting we plan to leave the Nitrous Outlet system on the car as well
- Vengeance Racing custom spec camshaft- VVT retained/DOD deleted
- Vengeance Racing Dual Valvespring Kit
- Vengeance Racing Hardened Pushrods
- Katech C5R Timing Chain
- Comp 850-16 Lifters
- Comp Cams Trunion Kit
- Comp Cams Phaser Limiter
- American Racing 1 7/8 Longtubes with CATTED 3" X pipe
- All tuning in house using HP Tuner & EFI Live VIA Vengeance PCM
That cam sounds mean, clean install Ron!
St. Jude Donor '08
Ron,
Should the rod/piston let go would you please let us know at what level that happens? I know most shops don't tell the customer when **** blows up. I know you are pushing the limit and i commend you for that! respect.
Former Vendor
If/when it breaks we will let everyone know. The whole point of purchasing a 70k vehicle so early is to find this stuff out so we can avoid it happening to our customers. We are truly doing this for the sake of research and development.
Former Vendor
There are several tables in the ECU that we do not have access to yet with the current software. We need to be able to adjust these tables due to the ECU using calculated torque to limit power output.
Received 2,048 Likes
Hats off to you guys, congrats! If the clutch gives you any troubles we have a solution
Former Vendor
I think that is the tuning issue they are trying to get around. The 1st graph you can see no issue. Past that something is pulling power or something.
Supporting Vendor
Great work guys!!
__________________
Worlds Quickest C8 Corvette 8.83@160MPH
FIRST C7 Corvette in the 7's & 9's
2019 ZR1 LT5 8.874 @ 155
Current C7 World Record Holder 7.55 @ 184 MPH
Quickest and Fastest GEN5 LT Powered Vehicle
LMR1200HP Supercharged C7 8.84 @ 160
LMR1200HP Twin Turbo C7 9.35@155mph-2014
2 TIME OUTLAW DRAG RADIAL LSX CHAMPION 2008/2010
9.47 ZR1 Corvette-2009
LATE MODEL RACECRAFT
713-466-9900
LateModelRacecraft.com
Too many PMs, please call or email instead, thanks!
713-466-9900
Former Vendor
Thanks guys! We are in the process of installing our new camshaft/ECS supercharger system/methanol system. We should have new #s next week.
