LMR650 Supercharged Build Photos
Old 02-08-2014, 06:00 PM
Late Model Racecraft
Supporting Vendor
Late Model Racecraft's Avatar
Default LMR650 Supercharged Build Photos
http://imgur.com/a/t1ih1
Old 02-08-2014, 07:28 PM
00hotvette
00hotvette's Avatar
Very nice. Did you put the hood vent back in?
Old 02-08-2014, 08:00 PM
Theta
Theta's Avatar
St. Jude Donor '14-'15
Is this one of the available kits advertised that's been installed, or is this an LMR kit?
I'm guessing it's the A&A kit, but I'm not for sure.
I really like the finishing on the intercooler.
Old 02-08-2014, 08:04 PM
Theta
Theta's Avatar
Fixed your links, btw.
Originally Posted by Late Model Racecraft
Old 02-08-2014, 09:05 PM
00hotvette
00hotvette's Avatar
Hey Theta looks like you and me are looking at installing a supercharger. Did you ever install the Pfadt headers?
Old 02-08-2014, 10:36 PM
ChucksZ06
ChucksZ06's Avatar
Nice looking work guys. Any rough idea on how much wt is added to car with sc and components?
Old 02-08-2014, 10:49 PM
Theta
Theta's Avatar
Should be right between 60 and 70 pounds.
Old 02-09-2014, 12:29 AM
peter pan
Life Time NCM #2196
Support Corvetteforum!
peter pan's Avatar
Received 1,095 Likes on 807 Posts
Very nice and detailed
Old 02-09-2014, 03:07 AM
3 Z06ZR1
3 Z06ZR1's Avatar
So this must be an early A&A kit. The kit will have less welds in the charge tubing. Plus it will be 8 rib! Interesting I have seen three intercooler placements now!
Old 02-09-2014, 01:25 PM
Andy@A&ACorvette
Platinum Supporting Vendor
Andy@A&ACorvette's Avatar
Yes, you are correct.
There will be no welds in the next batch of tubing. I'm hoping to have 25 sets any day now.
The hood vent does fit back in place. That was obviously very important.
I'm using SFI approved balancers with interchangeable rings, much like the CTSV balancers. We can go larger on the bottom as well as smaller on the top to change boost levels. It will be a very short dedicated 8 rib belt.
Even this early one looks really good, in my opinion.
Great job guys.
__________________
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
Old 02-09-2014, 02:03 PM
C7pimp
C7pimp's Avatar
Looks great!!
Old 02-09-2014, 08:04 PM
Motohead279
Motohead279's Avatar
Sweet!
Old 02-10-2014, 01:31 AM
3 Z06ZR1
3 Z06ZR1's Avatar
Great job guys.
I like your intercooler set up. I see the reverse flow the other guys are doing. I see your working better. Make mine in black V-3!
Old 02-10-2014, 02:37 AM
3 Z06ZR1
3 Z06ZR1's Avatar
Then when you add headers you take some weight back off the front!
Old 02-10-2014, 03:14 AM
Theta
Theta's Avatar
Around 20 lbs savings with LTs. Can take another 4-6lbs draining the washer fluid. Another 4 lbs removing the tank.
Not sure about how much would be saved by removing the wiper motors and wipers (probably around 10 lbs), and then there's just the superficial stuff that will save a few lbs here and there.
Could always lighten the flywheel for another 15 lbs, but that's not cheap (2-3k). For the amount of power added, though, the power added:additional weight ratio on these SC kits is very nice.
Old 02-10-2014, 09:23 AM
Motohead279
I also like the idea how the airflow to the IC is on your system. I am still a bit fuzzy on how the airflow on other systems will pull up from the bottom, and the efficiency of it.
Old 02-10-2014, 10:53 AM
Higgs Boson
Higgs Boson's Avatar
Received 2,378 Likes on 1,238 Posts
I pulled all the wiper stuff off my C5Z and it was like 5 lbs or less. Not worth it at all.
To LMR650 Supercharged Build Photos
Old 02-10-2014, 01:32 PM
Theta
Theta's Avatar
Good to know - it seems like way too big of a pain to mess with for that small of a savings.
Old 02-10-2014, 02:20 PM
Chris@East Coast Supercharging
Premium Supporting Vendor
Chris@East Coast Supercharging's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Great work guys
Old 02-10-2014, 04:02 PM
Zmoy2
Zmoy2's Avatar
Great job guys.
Did you guys Dyno your car with stock exhaust? And have you seen power gains, or loss, with the addition of headers?
Quick Reply: LMR650 Supercharged Build Photos
