Ready for third set of rotors!!! I can't be the only one
Old 10-15-2014, 12:50 PM
  #101
Jedi-Jurist
Jedi-Jurist's Avatar
St. Jude Donor '15
Originally Posted by JRitt@essex
To the OP...we have your solution! Our front and rear Essex Designed AP Racing J Hook Endurance Racing discs for the C7 Z51 are just about here. I expect them to start shipping before the end of November.
I'm working on the web page for them currently. I'll put a link up when it's ready.
Again, these are the same size as the OEM Z51 discs:
Front= 345x30mm, 72 vane J Hook AP Racing Disc
Rear= 338x26mm, 72 vane J Hook AP Racing Disc
They're going to retail for approximately $1200 for all four corners, fully assembled and ready to drop on the car. They use the same style of hat and floating mechanism as the discs in our complete Competition Brake Kits. If you look at our current Viper discs, they give you a good idea of what to expect.
Target pricing for replacement iron will be:
Front 345x30mm= $339 each
Rear 338x26mm= $329 each
These discs are beasts, and I don't expect people to be replacing the iron very often!
Essex Designed AP Racing J Hook Endurance Disc
That would be great! A few questions:
1. Will this work with the stock calipers?
2. Will they require/prefer specific brake pads? Will Carbotech's line work? Do you recommend anything else for the track & street (I prefer separate pads for each application) that would work better with this rotor?
3. I'm assuming no cooling ring, right?
Old 10-15-2014, 02:13 PM
  #102
JRitt@essex
Supporting Vendor
JRitt@essex's Avatar
Yes, our discs are designed to work with the OEM Z51 Calipers.
No, you can use any brake pads designed to work in the OEM calipers.
Yes, swapping between street and race pads is the ideal way to go. My standard recommendation is Ferodo DS2500 for the road and DS1.11 for the track. When swapping between the two they don't have many of the judder/vibration issues that we've seen with other pads. They're also easy to bed-in and don't destroy discs.
Absolutely, positively, no cooling ring!
Old 10-15-2014, 02:23 PM
  #103
TAK2TRK
TAK2TRK's Avatar
Let me know when these hit the market. They are exactly what i'm looking for. Do you have OEM v. AP weights? I'm assuming these will be slightly lighter with the Al hats--is that correct?
Old 10-15-2014, 02:54 PM
  #104
Jedi-Jurist
St. Jude Donor '15
Guess I'll be waiting a little while longer to replace those rotors. Don't drive it over the winter, so I've got some time.
Old 10-15-2014, 03:22 PM
  #105
JRitt@essex
Supporting Vendor
I'll be posting up about these when they're ready to ship.
I don't have the weights yet, but yes, they will each likely be a couple of pounds lighter than stock.
Old 10-15-2014, 04:04 PM
  #106
Rob Willis
Rob Willis's Avatar
Very nice.
Old 10-16-2014, 08:21 AM
  #107
leadville1
leadville1's Avatar
Your saying it is $1,200 for all 4? I thought it was going to be $1,200 per set.
Old 10-16-2014, 08:26 AM
  #108
JRitt@essex
Supporting Vendor
Wow...I dropped the ball on that one...good catch!
It's going to be approximately $1200 per axle set, or roughly $2400 for all four discs. Sorry to mislead!
Old 10-16-2014, 08:51 PM
  #109
Jacked
New Member
Jacked's Avatar
Has anyone tried these ?
Old 10-17-2014, 02:50 PM
  #110
descartesfool
descartesfool's Avatar
I am sure they would be good at making a ton of noise with wheels rotating while car is at 150 mph! Those fins might even start to straighten out to reduce air drag.
Old 10-17-2014, 02:54 PM
  #111
Jacked
New Member
Jacked's Avatar
No , these have been on the market for a few years. Short track racers use then. I didn't hear them over the sound of the exhaust (95db) at the track.
They are not a "snake oil" type of product.
Old 10-27-2014, 10:06 AM
  #112
Jedi-Jurist
St. Jude Donor '15
I liked it better at $1200 per car - maybe an introductory discount to thread participants?
Old 10-27-2014, 08:02 PM
  #113
Ben@WeaponX
Ben@WeaponX's Avatar
St. Jude Donor '14
I have two sets of Racing Brake rotors in stock still fellas for much less than list. PM me for best price
https://weaponx-c7.myshopify.com/pro...front-complete
Quick Reply: Ready for third set of rotors!!! I can't be the only one
