NGK Spark plug part numbers for C7 forced induction
02-22-2014, 11:26 AM
Does anyone have em? One step colder...
02-22-2014, 06:19 PM
St. Jude Donor '14-'15
There are a few different part numbers going around right now depending on the tuner.
Ask your tuner or FI dealer what they're recommending on the setup and tune you're using.
02-22-2014, 07:17 PM
St. Jude Donor '14
I'd be looking at the TR6 IX for most bolt on blower kit boost numbers... if you crank it harder, you might need to step into the 7IX
02-25-2014, 08:33 PM
Quote:
Originally Posted by
Ben@WeaponX
LT1 plugs are significantly longer than LS plugs, so NGK part numbers from the LS will not work in the new LT.
02-26-2014, 01:29 PM
Ben@WeaponX
You would need the LTR7IX-11 (6510) for an LT1 with boost
02-26-2014, 01:45 PM
lt1z
Thanks!! Much appreciated!!
02-26-2014, 03:45 PM
St. Jude Donor '14
lt1z
thx Matt
12-22-2014, 04:17 PM
thanks for the part number what is the next step colder? anyone run non-iridium?
12-22-2014, 04:31 PM
Former Vendor
MIGHTYM0USE
only brisk makes them.
12-23-2014, 01:35 AM
12-23-2014, 09:18 AM
does brisk have a part number?
yes nkg ltr7ix is 6510 10-4 and affirmative, seen it earlier in same post.
12-23-2014, 10:48 AM
Former Vendor
MIGHTYM0USE
Honestly I don't know it off the top of my head, I've used them in a few big power coyote motor builds (same plug)... Just call them up, they have various heat ranges.
12-23-2014, 01:31 PM
MIGHTYM0USE
I have a Procharger and that is what is recommended.
03-25-2015, 12:23 PM
anybody with a brisk part number?
03-26-2015, 02:11 AM
MIGHTYM0USE
Brisk RR14S
03-26-2015, 12:29 PM
am i reading wrong or is that brisk same heat range as the ngk 6510 i thought was 1 colder?
04-07-2015, 11:11 PM
what is the recommended gap for these plugs?
04-08-2015, 10:12 AM
ilivas
LMR recomended .25 which work great on my car
04-08-2015, 10:51 AM
I have some NGK 7IX plugs for boosted C7 if anyone wants them. I paid 90 bucks shipped, put them in, drove around the block, took them out, decided they are too cold for my bolt on motor and put the stock plugs back in.
$50 shipped
