Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- How to Install Methanol Injection
Step by step instructions for do-it-yourselfers.
** C7 ECS-ALKY Control meth injection systems now available for shipping **
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
Hi guys,
We have the C7 alky/meth injection systems finalized for shipping for your C7. This is the same system being used on what is presently the highest HP C7 in the world built by Vengeance racing, and is the same basic system we here at ECS have been using for 12+ years now on many of the worlds fastest/quickest supercharged Corvettes.
Installation is fairly simple with all necessary wiring, brackets, hose lengths made to fit specifically for your C7. Estimated install time is 6-8 hrs depending on your mechanical ability and a lift is helpful but not mandatory.
The standard single nozzle kit is $639
Dual nozzle upgrade add $75
IAT breakout, sensor-grommet-pig tail $50
When do we recommend meth injection?
meth injection is recommended for cars producing more power then pump gas can handle octane wise, or when you are in a very warm climate and the cooler inlet air temps -IAT's- provided from meth injection would be helpful for making consistent power.
We typically consider 600 rwhp the power level of pump gas, there are variables to that, but generally speaking.
This is basically octane on demand, this is a progressive system that ramps in meth per pound of boost which is all programmed by the installer as to it's rate of climb and turn on amount. Adjustments are simple and straight forward, but we do suggest that it is set once during the install/tune and left alone as this is fueling.
Additional benefits is excellent internal engine cleaning, the meth injection will keep the inside of an engine very clean, even a car with 100k on it will have piston with just a brown film on them compared to being caked with carbon, intake valves stay much cleaner along with the intake manifold.
Here are a couple of links to C7 builds using this system;
http://forums.corvetteforum.com/c7-t...-1000rwhp.html
http://forums.corvetteforum.com/c7-t...754-676-a.html
Most do not use meth at that point, but yes there are benefits. Especially with you being in a warmer region like Fl, it will keep the IAT's very cool regardless of how warm it is outside. That will maintain a higher power level consistently.
Also in the event of getting bad gas, you will always have enough enough octane to overcome any damage that can be caused. Methanol is 110 octane.
HT
