What are all the bolt torque settings for maintenance and track setup?
As the Helms manual is not yet out, I was wondering what all the bolt torque settings are one might need for maintenance and track setup.
Brake caliper and bleed screws and lines for rotor, pad and fluid changes front and rear.
Alignment bolts for caster, camber and toe.
Wheel nuts.
Oil drain and other fluid drain plugs.
Height setting bolts.
And any others one might need to torque up.
Wheel nuts.
ImHuntingWabbits (09-07-2018)
The following 2 users liked this post by Theta:
ImHuntingWabbits (09-07-2018),
JorgeAM (09-01-2020)
Wheel nuts.
Wheel nuts.
You are the source!
I will be running GM's track setting alignment specific for the Z51 using the Pilot Super Sports.
Front:
Caster: 7.0 degrees
Camber: -2.0 degrees
Toe: 0.05 degree toe-in
Rear:
Caster: 0.0 degrees
Camber: -1.7 degrees
Cold tire pressure: 26 psi
Front:
Caster: 7.0 degrees
Rear:
Caster: 0.0 degrees
Torque spec on the bolts holding the 2 halfs of the caliper together
I think I have not seen the above torque spec. Googling I found 130 but that seems very high. I did use that but the bolts barely hold that much force. They start rounding. Do you have the spec for that?
CTPJ (05-19-2018)
Received 8,918 Likes
Bill
Are you referring to the torque on the cams for the control arm alignment. Spec is 125 lb-ft. If your wrench is slipping make sure you're using a 6pt and not a 12.
Thanks for your Reply. I have a Z51. That has no bridge bolt. I’m looking for the spec for the 4 bolts that keep the 2 caliper bolts together. I just rebuild my calipers.
Since separating the caliper halves isn't a recommended service procedure there aren't any specs for the bolts that hold the two together.
I imagine they might be separated at a rebuilder or remanufacturing plant but not in the field. I suspect there may be seals that go between the two halves so brake fluid doesn't leak and I only see new pistons, dust boots and piston seals in the GM rebuild kit.
Do the threads in the calipers have some sort of steel insert in them? Any large amount of torque applied to the bolts could easily strip the threads inside an aluminum caliper if there isn't an insert. The maximum torque that could be applied to those bolts would be severely limited if all you have are aluminum threads. 130 ft lbs may have done more than round off the heads of the bolts.
My guess is with the size of those bolts the torque spec is more like 50 ft lbs.
Bill
Jan_N (05-22-2018)
