How-To: Bleed/Fill rear differential and hydraulic system service + specs
Old 06-15-2014, 01:56 AM
Theta
Theta's Avatar
St. Jude Donor '14-'15
Default How-To: Bleed/Fill rear differential and hydraulic system service + specs
The following How-To covers the explanation of the Rear Differential Bleed/Fill and Hydraulic System Service and includes specifications, schematics, etc.
These How-To guides are neither endorsed by or property of Corvette Forum or myself in any way/shape/form. All liability stemming from any actions taken in relation to these guides is solely placed upon the user.
We hope you will find these guides useful.
Popular Reply
Theta
Theta's Avatar
Theta
Theta's Avatar
Attachment 48371941
Attachment 48371942
The following 6 users liked this post by Theta:
alexsoo (03-13-2017), Bad Dad (10-11-2015), BigTree (03-26-2017), NortonCO (10-28-2019), PLRX (04-28-2016), robert miller (06-01-2016) and 1 others liked this post. (Show less...)
Old 06-15-2014, 01:57 AM
Theta
Theta's Avatar
Theta
Theta's Avatar
The following 2 users liked this post by Theta:
Bad Dad (10-11-2015), NortonCO (10-28-2019)
Old 08-07-2015, 02:41 PM
Jedi-Jurist
Jedi-Jurist's Avatar
St. Jude Donor '15
I'll admit I'm a bit confused - I have a '15 Z51 that I'll need to change the differential fluid at the end of the year since I track the car. I'm assuming that's just the first part and not the Rear Diff Service Bleed, right? Also, what exact fluid should I be using to refill? Just the DEXRON LS Gear Oil or the DEXRON VI (as it has an eLSD)?
Thanks!
Old 08-13-2015, 11:32 AM
Jedi-Jurist
St. Jude Donor '15
Thanks!
Bump for an answer please!
Old 08-13-2015, 04:07 PM
Theta
Theta's Avatar
You can follow the Differential Oil Replacement doc from the second post - that's the change you're referring to.
Did mine for the first time a week ago, and wondering why I didn't do it sooner. Aside from being completely contaminated with (large) chunks of metal, it has cleared up a few issues (and not in a placebo sense).
I used Royal Purple Max Gear 75W90 fluid on the recommendation of a few members here. I can't give any sort of endorsement, nor would I want to with the fluid arguments everyone has here. I'm satisfied with that fluid's performance, though.
The factory fill is, from post 4, Dexron LS Gear Oil. Three quarts and a hand pump (I use a cheap 4cc pump from Amazon) will work great. Just combine the extra from each bottle at the end, and it will take right at 3qt.
The following 4 users liked this post by Theta:
Bad Dad (10-11-2015), BlackMoon (07-26-2017), george vee (10-13-2015), NC94Vette (10-31-2015)
Old 11-11-2015, 03:20 PM
calgaryguy
Support Corvetteforum!
calgaryguy's Avatar
do these instructions work for a 2015 z06 a8 car?
96GS#007 (07-27-2018)
Old 03-07-2016, 08:20 AM
Jedi-Jurist
St. Jude Donor '15
Theta, do you know the tool you need to open the two plugs? Also, how do do get to the fill plug (pictured)? Just looking at it, I don't see how to get a wrench up there, much less a torque wrench.
Thanks!
Old 03-07-2016, 09:36 PM
Jet Vet
Jet Vet's Avatar
St. Jude Donor '15-'16
I just had the dealer drain and fill mine for the new HPDE track season. It wasn't too expensive and I don't think I could have done it without tearing something up, probably including my hands. The $$ are definitely worth the savings in hassle, IMHO.
JV
Old 03-08-2016, 05:42 AM
3X2
3X2's Avatar
Theta, is there any way to bleed the elsd without the engine running? I just installed a new diff and don't have the engine running yet- that's another long story with me trying to program the modules with this global A architecture. Anyways, it would be easier to do without the exhaust on the car.
Old 03-08-2016, 08:30 PM
xp800
xp800's Avatar
Theta has been worryingly absent since early September 2015. Given his medical issues mentioned at times, I do hope he replies some day.
Old 03-08-2016, 09:44 PM
ap6954
ap6954's Avatar
I am obviously not Theta but I drained and filled my 15 Z51 with new GM LS gear oil after a couple thousand miles and a few track days and it can be done with a socket wrench and flex extension. The plugs are just a square fitting on a 1/2" extension. You gotta work at it to get access. There may be a fancy tool for it but I did not need it. My fluid had just real fine grit that was normal for a rear axle just breaking in. I've seen a few in my day. Most of the grit was on the magenetic plug.
[QUOTE=Jedi-Jurist;1591715707]Theta, do you know the tool you need to open the two plugs? Also, how do do get to the fill plug (pictured)? Just looking at it, I don't see how to get a wrench up there, much less a torque wrench.
Old 03-08-2016, 10:21 PM
3X2
3X2's Avatar
Didn't know this.Hope all is well and Theta will be in my prayers.
Mark
Old 03-27-2016, 09:53 AM
Kracka
Kracka's Avatar
Received 5,716 Likes on 2,921 Posts
A flex-head 3/8" drive ratchet works perfectly. I did my differential and transmission fluids yesterday and completed the entire project in about 2 hours including set-up and clean-up. I plan to type up a DIY thread on it later today.
*edit*
Here is my DIY thread: https://www.corvetteforum.com/forums...d-service.html
Old 05-26-2016, 10:13 PM
Jedi-Jurist
St. Jude Donor '15
<br >
Thanks!
So after doing the change with Royal Purple, I get a knock from the diff when starting out (forward or reverse). I was told I need to add "Positraction Lubricant Additive." Can anyone confirm? How much do I need?
Old 06-01-2016, 09:08 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Default ttt
Man thanks for all of your help in here on how to do stuff. I did this job a few months back just put the car on the 4 post and wasn't bad at all. Robert
To How-To: Bleed/Fill rear differential and hydraulic system service + specs
Old 06-01-2016, 09:39 PM
Stingray Al
Stingray Al's Avatar
<br >
I used Redline Gear lube. I didn't have to add anything, no issues here.
Al
Old 06-29-2016, 06:04 AM
AKKutz
AKKutz's Avatar
Are the Lubrication Specifications posted somewhere?????
Old 06-29-2016, 08:50 AM
xp800
xp800's Avatar
Look in post #4...
AKKutz (06-29-2016)
Quick Reply: How-To: Bleed/Fill rear differential and hydraulic system service + specs
