So far....How far have people pushed the stock LT1 regarding WHP?
I've seen a few videos for 800whp without the use of nitrous.
What's the current record for whp (without nitrous as I'd like to know about "all-the-time" power) and how have the motors been holding up?
I'm curious about getting into a C7 but only if it can make at least as much or more power than my built-347 Twin turbo C5 does.
Is this the mythical "1000whp on a stock motor" engine many have been dreaming of or what?
The lower end ,crank and rods are forged and should be fine . Those Hyperutectic pistons ,not so much! Right now Its about 580 rwhp @ 8 lbs boost .
From what i see written here the future of my motor looks bright .Although based on our experience with our GN and Camaro I will be surprised. We do have a new tuner( Slowhawk in Mass.) maybe that will give us some longevity.
Im keeping the checkbook , " locked and loaded" ,just in case. Jim
St. Jude Donor '14-'15
There's actually a lot of faith being put into those pistons by respected builders and shops. That being said, even I wanted to swap them out...
The amount of detonation is the key factor in seeing how much (or little) damage is done. They didn't do us any favors in shaping them like that, either.
My C7 is at the shop getting an ECS/Meth/Headers so to say this article gives me a knot in my stomach is an understatement.....
And a quart of oil in the intercooler!? Yup I'm definitely going with a catch can...
It is the tune, ie how well it is done that is going to make the difference on the engine holding up or not. Not saying forged rods and pistons are not great insurance.
Supporting Vendor
No sir they do not. At least none of the kits we have seen so far do.
__________________
Worlds Quickest C8 Corvette 8.83@160MPH
FIRST C7 Corvette in the 7's & 9's
2019 ZR1 LT5 8.874 @ 155
Current C7 World Record Holder 7.55 @ 184 MPH
Quickest and Fastest GEN5 LT Powered Vehicle
LMR1200HP Supercharged C7 8.84 @ 160
LMR1200HP Twin Turbo C7 9.35@155mph-2014
2 TIME OUTLAW DRAG RADIAL LSX CHAMPION 2008/2010
9.47 ZR1 Corvette-2009
LATE MODEL RACECRAFT
713-466-9900
LateModelRacecraft.com
Too many PMs, please call or email instead, thanks!
713-466-9900
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,086 Likes
Several 700+ C7's out of here going strong, 100% stock engines. Only instance of oil usage has been on the road course from one vehicle out of three I know of so far. It's fine, just burped a little.
Indeed but it's a cheap thing to add, mine was $150 from Might Mouse Solutions for my C5. $150 is a drop in the bucket compared to the money spent on a blower/meth/etc.
so you're hitting 672 with completely stock motor? the guys who tuned it did a great job getting enough fuel with the stock cam and fuel lobe, who tuned it? do you expect to up the boost more with the stock cam even more?
#35
Better check your C7 out in stock form first. If you pull your intake bellow infront of the throttle body and find oil. I would not add a blower kit. My car has been sitting as I struggle with the oiling issue.
Oil comes out the BOV. If you car is oiling and you add a kit your going to have issues. I even have a catch can. It just a bandaid for a non healing problem. In the next day or too I hope to figure it out with new info on how to fix it.
I can clean it all out. Then have the oil down a qt. Drive it 20 miles and have oil everywhere. It sucks!
#36
Received 2,379 Likes
There are plenty of boosted LT1s (and DI truck variants) out there with no issues, which means its your car as the anomaly, not the norm.
If you your issue is really that extreme, Corvette Forum is not where I would be right now.
#37
#38
A&A must route to the stock location (airtake tract) for the EPA cert.
My sump was routed to the intake with the PVC lines.
They used to route to the airfilter or box like ECS. I'm changing mine over to the ESC style. Hopefully that will fix my problem.
#39
Sounds like you might want to get a second opinion on your setup....installation error. Maybe they thought it would be a great idea to boost the crankcase instead of the combustion chambers.
here have catch can on the stock car. Might want to do that instead
of looking silly by suggesting it is an install error!
Then my car is the only one?
Forgetting that GM has a servive bulletin out for this issue too?
#40
I have the instruction's from ECS that I'm doing right now to get it ready.
