How-To: Perform/Check Front/Rear Wheel Alignment
St. Jude Donor '14-'15
can someone explain which way to rotate the alignment plate to achieve more negative camber? Do each notch represent a certain amount of degrees? Also, how do you rotate it (any special tools involved)?
I've done alignments on other cars, but am unfamiliar with the corvette setup. Thanks.
Can you comment on the need to remove washers in order reach the track specs. My dealer was able to get the camber on the rear but then could not get back to the toe spec. They gave me the car with .8 toe out in the rear. I brought the car home and removed one washer from under each of the mounting points on each side. Then took it back to the dealer, they were then able to get it to spec but wanted to charge me for two alignments.
My argument is that this is a GM spec and shouldn't have been an issue.
Thanks.
Thanks.
Received 8,928 Likes
Thanks.
Thanks.
They are just trying to charge you for the mechanic's lack of knowledge.
Bill
(Took one set of the washers off of the upper a-arms before adjusting as well.)
It isn't an issue with it being a GM spec or not. The dealer mechanic should have known enough to remove the washers. It has been that way on Corvettes since the 97s came out. The first time I took my 97 into a dealer for a track alignment the mechanic showed me where he removed the washers to get the range of adjustments required. He even bagged the washers for me so they would be available to reinstall when I went back to a street alignment. Mine was the first C5 alignment he had done and it was no big deal. I take it there are other GM products that have a similar setup so it isn't something strange to them.
Bill
Bill
It varies depending on whether you have a Stingray, Z51 or Z06.
Bill
Can anyone explain why they say to remove ONLY 1 washer (not 2) ?????
I have removed 2 washers from all my A-Arms.
What problems can this cause (if any) ?
I did this to be able to get -2.0 camber in the rear.
How important is rear caster ?
I have not checked for this at all.
Sr.Random input generator
I can't imagine any reason why 2 washers vs. 1 would make any difference.
Regarding rear caster, it turned out to be quite important. I'd highly recommend that you get it done. My adapter for rear caster adjustment will hopefully be shipped next week.
I think that max 1 washer advice is there merely since you are supposed to hit the targets with one washer, and taking more off might make it impossible to hit the targets (keep in mind the bulletin is not for us, but rather for the dealer; dealers are not supposed to go off-spec even for track).
Bill
#33
The only reason that I can think of is my Z06 came with 2 washers/spacers on the front corners and only one spacer on the rear corners. There may be some frame wear issue with having the dog bones pressing directly against the frame Vs riding on at least one spacer. I don't know how many spacers are behind the Z51 rear ucas but it may be two. When the suspension is moving up and down there may be some movement of the dog bones relative to the frame and a spacer between the two would minimize rubbing.
Bill
Bill
#34
So today I took it in to my local Dealer.
I had arranged (last Monday) for this, explaining things to him.
He said my rear caster was about 2.x deg neg on one side, and about 1.9 deg neg on the other.
He also said my toe in was very excessive.
So we changed things... we now have...
Front Caster 7.4, 8.0, Camber -2.5 each side, toe .05 deg (out) both sides
Rear Caster 0 both sides, Camber -2.0 both sides, toe zero both sides.
Based on what I have been reading it is entirely possible this might have been my
problem all along (rear caster).
But I was throwing all sorts of things at it in desperation.
This Saturday we have another event... let's see how things go.
#35
TIA,
Bish
#38
#39
Terrific F&R Alignment write up that I can now take to the dealers who say, "My tech says he doesn't need any of this." Sure gets old hearing that crap which says, "We do a half *** alignment."
Thank you Theta, thanks to all of you who contributed. You are truly appreciated.
