How-To: Perform/Check Front/Rear Wheel Alignment
St. Jude Donor '14-'15
The following How-To covers the explanation of how to Perform/Check the Front and/or Rear Wheel Alignment and includes specifications, schematics, etc.
These How-To guides are neither endorsed by or property of Corvette Forum or myself in any way/shape/form. All liability stemming from any actions taken in relation to these guides is solely placed upon the user.
We hope you will find these guides useful.
The following 2 users liked this post by Theta:
Bunk (06-16-2016),
Magister Ludi (05-24-2016)
Do the GM tech's have access to this? They seemed like they were not sure where to start on my car with doing this. They aligned it twice because they were setting parameters in the wrong order.
This seems pretty self explanatory.
Received 8,963 Likes
Makes me wonder how a DIYer like me will be able to set the alignment if the rear caster is critical to performance. First time I have seen a car that required rear caster to be set. Even my C6Z doesn't specify that even though with 2 upper and 1 lower rear camber adjustment points it would be possible to adjust rear caster to some degree.
Bill
Bill
Could you please put the track alignment specs in here so it's all in one place?
