C7 LMR 750HP Package
Supporting Vendor
Pulley received, should have final results by tomorrow.
__________________
Worlds Quickest C8 Corvette 8.83@160MPH
FIRST C7 Corvette in the 7's & 9's
2019 ZR1 LT5 8.874 @ 155
Current C7 World Record Holder 7.55 @ 184 MPH
Quickest and Fastest GEN5 LT Powered Vehicle
LMR1200HP Supercharged C7 8.84 @ 160
LMR1200HP Twin Turbo C7 9.35@155mph-2014
2 TIME OUTLAW DRAG RADIAL LSX CHAMPION 2008/2010
9.47 ZR1 Corvette-2009
LATE MODEL RACECRAFT
713-466-9900
LateModelRacecraft.com
Too many PMs, please call or email instead, thanks!
713-466-9900
Supporting Vendor
Well guys the results are in! After a quick pulley swap we were able to make almost 12psi of boost and significantly change the car!
Supporting Vendor
Should have some more videos up hopefully by next week of some more LMR C7 builds. You guys are going to love them!!!
Supporting Vendor
How will this 750 hp package 844 rwhp stack up against your TT800 PACKAGE ? Is the twin turbo just a better way to make power and can the TT be turned up to get much more power than this system? Both builds are awesome. I really enjoy the builds.
One more question which is off topic. What will your first mods be on the new Z ? Tune, CAI, pully swap?
#33
Supporting Vendor
LMR800 Supercharged(Heads,cam,headers,superchar ger system and other necessary components)
LMR800 Twin Turbo Package
***Our website needs to be adjusted***
The main difference between the LMR800 supercharged vs LMR800 Twin Turbo package is the ability to turn the power up in the future. The supercharged package head unit is only rated for around 900 flywheel horsepower where our twin turbo system can be turned up to 1200 flywheel horsepower with the correct additional components.
Also the way the power comes on is completely different. The centrifugal supercharger has a very linear horsepower curve and makes peak boost at higest RPM of engine while the Twin Turbo package can make peak boost by 4500rpms on a stock engine and even quicker with a built engine.
You also have drive ability difference. The supercharged package can be a little more noisy than the Twin Turbo package. The twin turbo package is more stealth. When idling and driving you can hardly hear anything until you step on the gas.
