WeaponX build thread - reviving the 427 Corvette!
Old 08-01-2014, 08:47 PM
  #41
Ben@WeaponX
Ben@WeaponX's Avatar
St. Jude Donor '14
Originally Posted by Rick@Redline-MS
Real Nicey Nice 427 concept with stellar execution results Gent!....
Looking forward to the roller numbers on the finished product....
Thx Rick! I have my hopes, we'll see where it ends up.
Originally Posted by djfury05
Nice build.. In case I missed it, any plans for head/intake work?
As a matter of fact, yes indeed
Originally Posted by DRLC5
Real Nice Build, should be a real *** Kiker. any chance for you to bring it to Florida for the FL2K14 Event in October?
I'll have to see what's up. The TX Mile is in Oct as well bro
Originally Posted by stangkilrproductions
More info on that VVT delete cover!
Funny, I thought of you when I put that in there
Old 08-01-2014, 08:58 PM
  #42
Ben@WeaponX
St. Jude Donor '14
Default weaponX LT1-395CFM cylinder heads
We chose to venture into the unknown with a big valve LT1 cylinder head setup. We were getting 350CFM like most out of the OEM valves, and thought, why not go bigger? These LT1 heads really put it down with up to 395CFM at .700 lift!
SEXY!
Old 08-01-2014, 11:56 PM
  #43
Ben@WeaponX
St. Jude Donor '14
Default 1,500 miles on the clock, time to get this motor OUT!
With 1,500 miles on the clock and not seeing anyone have gone as in depth to drop the chassis yet, Blake from Big Dog Performance and I got into it!
A shot of the bottom of the weapon7 diffuser - so vaney! loll
wheels down
We carefully removed that beautiful carbon fiber Halltech CKN
Further validating the need for a catch can!
Water pump coming off
This is the reason there are no aftermarket thermostats yet!
Old 08-02-2014, 12:09 AM
  #44
Ben@WeaponX
St. Jude Donor '14
Default C7 Exhaust removal
The NPP Z51 exhaust is a nice feature for sound, but it definitely would hinder the performance I'm after. The AFM valve OD is surprisingly small.
Open skinny outlet pipe
A rare look at the e-diff
NPP exhaust and mid pipes out
Old 08-02-2014, 12:14 AM
  #45
Ben@WeaponX
St. Jude Donor '14
Default 375mm Pirellis on PUR LX12s
Great shot of the 375s vs the 255 fronts! lol
Old 08-02-2014, 12:27 AM
  #46
Ben@WeaponX
St. Jude Donor '14
Default Drop it like it's HOT!
Chassis down!
Manifolds off
Engine hoist in place
LS vs. LT engine stand problems lol
Trans, converter, e diff
Old 08-02-2014, 08:30 AM
  #47
DocHolliday
Support Corvetteforum!
DocHolliday's Avatar
Damn Ben...this thing is badass!
Old 08-03-2014, 04:09 PM
  #48
Ben@WeaponX
St. Jude Donor '14
Default Time to bore the block at BES!
In order to achieve the maximum flow out of the over sized valve heads, I want a larger bore. With the motor out, I then hauled it to Bischoff to be disassembled and the block bored out for new Darton sleeves.
Old 08-03-2014, 09:32 PM
  #49
Motohead279
Motohead279's Avatar
Great google mooglie... You aren't messing around.
Old 08-03-2014, 11:01 PM
  #50
EvoX2008
EvoX2008's Avatar
This is going to be epic...
Old 08-04-2014, 12:51 PM
  #51
Sgoochds650
Sgoochds650's Avatar
Where are you getting your sleeves? Where your original bores a coated bore or bare?
Old 08-04-2014, 12:55 PM
  #52
Sgoochds650
Sorry just saw it was Darton sleeves.
Old 08-04-2014, 03:01 PM
  #53
Ben@WeaponX
St. Jude Donor '14
yea sorry bro, didn't see that question till I went to get the pics out of my other teaser thread so I put that in here for ya
Old 08-04-2014, 10:35 PM
  #54
Ben@WeaponX
St. Jude Donor '14
Default Assembly of the LT1 427!
With the block prepped for some magic, it was time for Brett Vonder Meulen of BES to take the reigns of reassembly.
Darton sleeved LT1 block
Wiseco custom spec pistons with a pretty healthy CR
Callies Magnum crank
Callies Ultra rods
Front cover
Rear cover
Valley cover
Gear
Oil pump
Old 08-04-2014, 10:51 PM
  #55
Ben@WeaponX
St. Jude Donor '14
Default Hope we're not left over with any extra parts!
Brett was off and running... getting the bearings in the block before the crank
Mains
Secret sauce cam! Needed a converter
Old 08-04-2014, 10:55 PM
  #56
Ben@WeaponX
St. Jude Donor '14
Default Around to the front! VVT?
Tell'em what time it is!
Old 08-04-2014, 11:01 PM
  #57
Ben@WeaponX
St. Jude Donor '14
Default Piston showdown!
wimpy wimpy wimpy... hefty hefty hefty!!!!
OEM hypereutectic 4.065" pistons and rods vs. Wiseco forged 4.125" pistons and Callies Ultra rods
To WeaponX build thread - reviving the 427 Corvette!
Old 08-04-2014, 11:10 PM
  #58
Ben@WeaponX
St. Jude Donor '14
Default The devil is in the details
Before we hang the pistons, Brett carefully checked the piston specs in the block.
Old 08-04-2014, 11:15 PM
  #59
Ben@WeaponX
St. Jude Donor '14
Default Checking the PTV
Bolt on one of the 395CFM super heads to check the PTV!
Old 08-04-2014, 11:20 PM
  #60
Ben@WeaponX
St. Jude Donor '14
Default Specs are perfect, time to let some pistons hang!
With everything well within specs for the LT1 427, next Brett begins loading up the pistons and rods.
Quick Reply: WeaponX build thread - reviving the 427 Corvette!
