Help: gas fume smell after SC install
Thanks,
Jim
I installed a check valve in the EVAP line to keep boost from going there. You can check out my supercharger pics album if you want to see how I did it.
I can't thank you enough for the info. I'm not sure how to access your supercharger pics but I would like to see them. Did you initially have the same problem? Thanks again, Jim
does the evap valve on this car not hold up to pressure like previous models, or does for some reason the computer run evap cycle even at full load?
Here are some great little check valves that are safe for automotive uses: http://www.usplastic.com/catalog/ite...3369&catid=489
They seal well, open easily, and are cheap to replace if you ever need to. I have a ton of these things that get packaged into a kit I sell and have never had a failure.
Another great valve is the PCV valve from the MKIV Toyota Supra Twin Turbo, but only if you get the OEM one as the aftermarket equivalents are typically junk.
What I think is happening is the blow off valve is located behind the bumper. The "bad air" from this sits in the bumper well and is pulled into the cabin air vent in the bumper. Still working on fix with the manufacturer. I will update once it is truly fixed.
Here is the part number for the actual GM part that is shown in the ECS instructions.
GM P/N is 12633414
It directly clips onto the solenoid valve on the side of the throttle body after removing the evap line connector. It has a barb that 3/8 hose fits over fine and then just cut the original plastic tube and slide the hose on and clamp. Very clean OEM part made for this purpose.
bob
GM P/N is 12633414
bob
GM P/N is 12633414
bob
GM P/N is 12633414
bob
Interesting. This is in the new ECS instructions I am assuming?
#33
The only reason it is supplied is to provide redundancy to the evap solenoid. In the event it would fail the check valve would prevent boost from pressurizing the system. There have been no issues that caused this to be added.
#34
Thinking this check valve played a role in the solution of oil in the intake as well? Or am I thinking of something else?
#35
#36
