Dealer detecting Diablosport - any reports?
Well, I like my job too much to just tell you how we do it
We simply spent some time looking at how the CVN process works, and found a way to do what we needed. It has been verified to not show up by a 3rd party member here and I have tested it countless times.
No guarantees as to what you asked. We have no way to know what happened, or if you told them you tuned the PCM, or if it had previously been flashed by some other non GM method, etc.
Mike,
I found this note in the Trinity Owner’s Guide. I assume if this procedure (restore “Original Backup”) is not followed then your tune will be seen by GM and the CVN not be the original.
Supporting Vendor
The CVN is never changed with our tool.
__________________
Mike Litsch
DiabloSport/Range Brand Manager at Holley
Trinity T2 and inTune i3 now available for 99-19 Vettes!!
Subscribe to our YouTube Channel!
Mike Litsch
What software updates ?
If there is an expensive warranty issue with the drive train GM can detect if there ever was use of a programmer by doing a process called a DNA search of the computer which will detect it and the complete history from the moment the computer was activated at the factory. Since I put a 7 year warranty on my C7 I would not take a chance with any aftermarket tuner no matter what the tuner manufacture claims.. .
hey mike, sorry to ask on here but didn't think it needed a new thread, any idea when you'll have support for the 2015 A8??
Supporting Vendor
Supporting Vendor
Uh... Revive an 11 month old thread to ask a question about...a Camaro.
Had you taken the time to look at the DS web site, you would have found your answer. But I'll save you the 20 seconds: yes.
#35
No they didn't detect mine I had the engine replaced by warranty and befor they replaced it they sended out the ecu to GM t see if it has bin tuned befor they can replace the engine long as u return it back to stock your good
#36
I wanted to see if Dialblo would still publicly confirm that question in 2015. I was told they removed that it was undetectable from their website. Now all I see is reminder to roll back the tune to the original settings which sort of implies but doesn't state it's undetectable.
#37
#38
Supporting Vendor
Still works the same way today.
#39
Im gonna assume that this stealth benefit is only there when your diablosport tuner is used with your supplied tune. Meaning that if a tune on the trinity for an ECS blower is installed, then the blower is removed and stock tune reinstalled, the checksum would be changed and dealer would know??
