Let's talk camshafts
In my case looking at a blower cam for my lil ecs1500. Why run 116 and then add +4 or +3? Will that help in getting more power under the curve? In N/A builds I have always down tight LSA's like 110 or most 112.
From what I understand advancing the cam can help with low end power. Is that right? So can you run more duration and not sacrifice as much low end by advancing the cam?
Received 2,379 Likes
just call a reputable company and let them spec it for you.
228/234 .617/.617 with a 116+4? This appears viable based on what I have researched so far.
Supporting Vendor
Say you have a 243/247 112+2 cam as your NA cam here are the valve events
IVO is 11.5 ° BTDC ( - indicates ATDC)
IVC is 51.5 ° ABDC
EVO is 57.5 ° ATDC ( - indicates BTDC)
EVC is 9.5 ° BBDC
Overlap is 21 °
But say for a blower car (Hypothetically speaking, This is just for example to show how changing stuff effects valve events) you wanted a 243/247 116+3
IVO is 8.5 ° BTDC ( - indicates ATDC)
IVC is 54.5 ° ABDC
EVO is 62.5 ° ATDC ( - indicates BTDC)
EVC is 4.5 ° BBDC
Overlap is 13 °
Now look at what has changed just by widening the LSA and adding another degree of advance.
There is lots of posts on topics like this online if you want to read more into it. Alot more goes into picking a cam than just picking numbers.
-Reid
**disclaimer**
I am not saying either of these cams are ideal for what i listed them as. These cams were just examples.
__________________
Worlds Quickest C8 Corvette 8.83@160MPH
FIRST C7 Corvette in the 7's & 9's
2019 ZR1 LT5 8.874 @ 155
Current C7 World Record Holder 7.55 @ 184 MPH
Quickest and Fastest GEN5 LT Powered Vehicle
LMR1200HP Supercharged C7 8.84 @ 160
LMR1200HP Twin Turbo C7 9.35@155mph-2014
2 TIME OUTLAW DRAG RADIAL LSX CHAMPION 2008/2010
9.47 ZR1 Corvette-2009
LATE MODEL RACECRAFT
713-466-9900
LateModelRacecraft.com
Too many PMs, please call or email instead, thanks!
713-466-9900
Supporting Vendor
That isnt necessarily true. The VVT has a very limited amount of movement. The idea is to get as close as possible with the camshaft, then do the fine tuning with VVT.
Lobe Separation angle is just a result of correct valve events. A cam should be picked by valve events and the LSA and advance that is needed to get the valve events you want are just by products.
IVC is 51.5 ° ABDC
EVC is 9.5 ° BBDC
Overlap is 21 °
IVC is 54.5 ° ABDC
EVC is 4.5 ° BBDC
Overlap is 13 °
-Reid
**disclaimer**
IVC is 51.5 ° ABDC
EVC is 9.5 ° BBDC
Overlap is 21 °
IVC is 54.5 ° ABDC
EVC is 4.5 ° BBDC
Overlap is 13 °
-Reid
**disclaimer**
LMR. Great explanation.
