Driver seat memory problems
2nd Gear
I programmed the driver seat in my C7 Corvette convertible. There is no problem exiting the car when I open the door of the seat goes back the steering wheel goes up. The problem is when I enter the car, when I open the door the seat moves forward and the steering wheel moves down to the drive position making it hard to get in the car. Is this a design flaw or have I programmed it wrong?
Programmed wrong. You can change the settings on the main screen in the dash. I prefer to have the seat move to driving position when I start the car; With the car off, my seat move to exit position when the door opens.
It's in the settings menu on the main screen.
Nothing is difficult; just not very intuitive.
2nd Gear
The new update will allow you to not have the seat return on opening the door, but it will return if you simply press the start button. Then you can press the clutch and hit the start button again.
It will also automatically return if you are able to just start the car from the exit position (I can).
If you search through the general forum's "Reported problems" thread you will find this information. I got mine flashed about 2 months ago or so.
