Anyone installed a Procharger D1SC w/the increased fuel cam?
Has anyone installed a ProCharger D1SC unit with one of the cams with the increased fuel delivery? Results?
Also, how far has someone pushed the stock fuel pump with just the modified fuel lobes?
I'll most likely be swapping the P1 to the D1 in a month or two and I'll keep the complete stock fuel system. From what I've been told the stock fuel system should be fine to about 650 rear wheel.
So no one?
Received 2,379 Likes
I plan to install a supercharger with the stock fuel lobe and Z06 pump/injectors
St. Jude Donor '08
As you know, the Z06 will be using a bigger fuel crossover and supply pipe and higher capacity fuel injectors using beefier mounting bosses along with the higher fuel pressure pump. Can any of these other parts be used on the LT1?
not sure yet but there are some interesting fueling options available even today right through the dealership.....more information forthcoming I am sure.
St. Jude Donor '08
From what i have been reading Stock cam Lobe will only get you to 600-630 depending on Dyno. I would to get my car up to 700 without doing a cam.
I am hoping the Z06 has a larger fuel pump setup that is compatible with my car. My car made 608/570 on a dyno jet.
What options are available through dealership for Lt1 ?
I want Pro charger but want the zo6 improved, radiator, thoughts ? never had boost and this is my first c7. I don't want cam, also thoughts on CMU tuners because I have Trinity hand held, maybe I can save a few, also just want safe, My buddy blew his hemi after a "forum tuner shop " on here CF told him he was safe. don't want that to happen to my LT1, what do you recommend really don't want to spend a ton of $ a little off topic but didn't want to start new thread..
Premium Supporting Vendor
We stock the upgraded fuel lobe camshafts for anyone looking to turn up the boost. Just be careful going to crazy as you can still out run the pump in the tank!
I agree, the stock fuel system cannot feed a D1/SC, I am still working on the requirements but my best guess right now is that a second in tank pump and a quad lobe (#21979) cam is required to run a D1SC without a restriction plate or some form of Meth injection.
St. Jude Donor '08
Btw a month of driving my car in this ridiculous heat 100+* and the car is running great. You will love your C7 with a blower. make sure you get a quiet BOV.. I had Andy put a quieter one on is Original was Stupid loud
which kit are you going with?
