Hinson Motorsports High Performance Urethane Engine & Transmission Mount Combo Packs
Former Vendor
C7 Urethane Engine & Transmission Mounts
MADE IN THE USA!!!
The Hinson Motorsports Performance Urethane Engine & Transmission Mounts are Now Available for the C7
The Urethane Performance Mounts you all know and love are now available for the 2014 C7 Corvette.These urethane engine mounts are designed for a great balance between engine control and vibrations. They have been tuned for both street and track applications. Replace your stock rubber mounts for improved throttle response and reduced engine movement.
Features
* Designed for street and race cars
* Direct replacement for stock rubber mount
* Uses factory metric nuts (not included)
* Stainless Steel construction for rust free operation
* Interlocking design for fail safe operation
* Uses factory heat shield (factory heat shield is required)
* Fast installation
Applications
2014 C7 Corvette
*NOW AVAILABLE IN SHORT & STANDARD HEIGHT ENGINE MOUNTS AS WELL AS COMBO PACKS
CLICK HERE FOR PRICING
Why Are They So Much Better?
As you can see in the below cut away image, the engine rides on the durable urethane. This is how we control engine movement while not passing every vibration in to the passenger compartment. The inside of the mount is interlocked. Even if you found a way to damage the mount, the stainless interlocking design will keep it all together. The design is built with stainless steel, so they will not rust. They accept your factory nuts. This means there will be no emergency hardware store trips.
Former Vendor
These are the best engine and transmission mounts on the market. No matter if you plan to put big power down or stay completely stock these are a must have.
Former Vendor
The shorter mounts are designed for cars that need a little extra hood clearance for things like superchargers etc. The shorter mounts are 3/8in shorter than the standard mounts which are stock height.
