Ported & coated stock exhaust manifolds
The OEM manifolds have been flow tested and they're working on the porting. All the data will be posted once they're satisfied with the final product. Then we'll move on to the dyno testing portion!
Wow! That would fill an entire delivery truck... PM sent.
I will say the OEM manifold flow is very imbalanced between runners.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
EXTRUDE HONING is another method of getting the insides smooths as silk and also getting the most out of the internal porting. Remove the big stuff with a burr and then extrude hone the rest. After you get the porting square, the coating will be the frosting on the cake. My coated headers made a world of difference on my 02 ZO6 as far as a major reduction in temps under the hood.
I don't have a C7 but, I'm still very interested in the results of this project.
Bill
Bill
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I dont have a C7 but, Im still very interested in the results of this project.
Bill
Bill
I too am lurking here to see what innovative ideas pop up. Extrude honing will not correct for unequal length runners. It works best on "cast" manifolds. I read somewhere in the massive amounts of LT4 pre-production articles that the exhaust manifolds were being made of sheet stainless steel. Just sayin.
Update on my current project:
My shop is working on perfecting the porting on each runner to not only increase the flow, but also balance it.
Cool! Keep us posted with your progress. Hope you are right about the SS casting too.
Porting and flow testing is done, at the coaters now.
#33
"Stainless steel exhaust headers and an aluminum balancer that are lighter than their LT1 counterparts."
Source: http://www.chevycorvette.com/2015-corvette-z06
#34
#35
The results are in! I have the flow charts, and while I'm compiling all the details, here is what we found:
-Average flow improvement of 13.8%
-Runner imbalance reduced from 7% to <1%
#37
Here are some pictures (prior to ceramic coating):
Work in the collector to reduce runner imbalance:
Stock:
Stock:
#39
Coming, have to get them on my car first The data we have so far is what we found on the flowbench. Real-world dyno testing will be next.
#40
