LT1 352CFM Boosted and N/A assembled heads in stock
St. Jude Donor '14
I have sets of brand new CNC'ed LT1 heads boxed up and ready to ship. They're flowing an astounding 352CFM over 297CFM stock! Note the significant gains above .550 as the stock head flow starts to decrease.
$1899 shipped with core exchange
Boosted setup has compression lowered - 66 cc chambers
N/A setups have compression raised to 11.7:1
Included:
Includes fully CNC ported intake and exhaust ports, custom valve jobs, bowl blending, blending of core shifted intake and exhaust ports, milling for desired compression ratio, build sheet, final wash and assembled. (315cc/116cc)
Double springs, titanium retainers, locks, seals
Rockers with trunion upgrade
Included:
How much without core?
What's stock compression on c7?
While I'm asking questions, are any of your cams designed for blowers, specificly centris?
I'm thinking my next mod will be heads and cams :-)
St. Jude Donor '14
OEM is 11.5:1 CR and we can go down for boost.
Yes I have blower cams so you can overdrive fuel pump and make more power with more boost and lower CR. E85 and my flex fuel sensor will help you with the tuning window too at approx 105 octane but the Z06 mechanical pump will be needed for that.
Flow benches are like dynos and vary as I've seen other places post them at 330 CFM if I recall. The important part is the gain and these are at 60+ CFM! My big valve set are +100 CFM!
