STS Remote Turbo Systems Released for the C7!
Former Vendor
You've seen the Prochargers, the Edelbrock, and the Hennessey supercharger kits hit the market running. STS is here to bring something a little different to the table.
[B]If you're not familiar with STS and their remote system here are a few key elements:
*Easy installation, bolt on a kit in hours
*No need for major modifications to your vehicle
*No Need for an expensive custom exhaust
*Lower Underhood temps
*Converts back to Stock in about an hour
The C7 Corvette radiator shroud & hood vent were designed with dual duties in mind, to provide cool air to the radiator and to reduce front end lift at high speed. Either one of these jobs are very important by themselves but to ask one component to do both takes an immense amount of design and engineering.
That is one component that you DO NOT want to modify!
STS Turbo twin-intercooled design there is NO interference or modification of the airflow through the radiator shroud while still providing the low intake & under-hood temperature that STS is known for! Unlike most C7 intercooler designs the installation of the STS twin-intercooled design is VERY simple and requires MINIMAL modification to the car. This is an innovative design from STS Turbo exclusively for the C7 Corvette!
The STS C7 Twin Turbo System has also been designed to use oil-less turbos! These custom built turbos are built in the USA and designed specifically for remote mounting and utilize a 500HP (1000HP total) capable billet compressor wheel and patented triple ball bearing design. With this proven triple ball bearing oil-less design there is no need to tap into the factory oiling system for turbo lubrication and cooling. This design allows us to NOT introduce any more wear or contamination to the engine oil allowing it to focus solely on keeping the engine lubricated. This is just ONE reason to choose the non-intrusive nature of the STS Turbo System.
Evan Sanza (01-13-2022)
Can you please PM me with more information; availability, pricing, other mods / tuning needed as well as expected RWHP. Looking at supercharging my 14 C7 Z51 but, this might also be an option. Also where you are located and if there is an early adopter discount. Thanks, TK
St. Jude Donor '08-'09
x2 for numbers, I love the idea and simplicity of rear mount turbos, only one thing bothers me, Clean air! Do you have any photos of air filter placement? Also, you mention oil-less are they coolant-less as well?
-Carl
-Carl
Love STS kits for their sound but I hate their price tag on their kits!
Had a STS kit on my C6 for 7 years and enjoyed it very much so.
I tried to give STS a chance to get on my C7 but they took too long. Plus I like being able to switch my NPP when State Troopers are around. Here in VA they love to give modified exhaust tickets.
Former Vendor
The filters mount right above the turbos, I'm working on getting some pictures from STS on the exact configuration. Loose power numbers within conversation is 650whp at the moment with their current tuning partner. The weak link seems to be the factory fuel pump and they are hoping for a solution in the future to drag out more power, but this is the comfortable limit they have currently for a reliable daily driver car.
These are oil-less but will need to be water cooled, if you have had experience in the past with remote turbo kits you will be grateful for this improvement, no worries of oil foaming, additional oil pumps, or smoke issues if not installed dead on correct.
Former Vendor
The kits can be ready within 2-3 weeks to ship
Pricing is $12,570 MSRP, this is higher than the previous C6 kits for two primary reasons; the new oil-less comp turbos and the twin intercooler design. This is priced for a complete kit with methanol, heatshields and boost controller, less these items saves $850. The kit does come with a tuning solution
just so everything is out in the open i will list your answers on the thread to avoid duplicate pms.
the kits can be ready within 2-3 weeks to ship
pricing is $12,570 msrp, this is higher than the previous c6 kits for two primary reasons; the new oil-less comp turbos and the twin intercooler design. This is priced for a complete kit with methanol, heatshields and boost controller, less these items saves $850. The kit does come with a tuning solution
Former Vendor
Install is pretty straightforward, keep in mind you are not tapping into the oil pan, removing an intake manifold, or swapping exhaust manifolds.
Saw the car on display at SEMA last year. Im suprised it took this long to get it completed and to production. Hopefully it can generate a HP/TQ curve that can justify the cost as it comes in at more than twice the price of a ECS or A&A blower kit and we all know what they are capable of at this point.
Looking forward to results.
Former Vendor
After talking with STS, the delays came down to their tuning solution. They went back and forth with a few options until they found an option they were satisfied.
Just so everything is out in the open I will list your answers on the thread to avoid duplicate PMs.
Look, I have done TT setups in the past, but this is just CRAZY pricing for a kit that does not even require manifolds
Sorry, in all reality it should be close to half that.
