2014 Manual Transmission Trouble
5th Gear
My 2014 C7 with 7 speed manual transmission grinds when shifting from 1st to 2nd and 2nd to third when cold. After the fluid warms the problem stops.
I took it to the dealer at 500 miles and again yesterday at 2800 mi. According to GM, this is normal. However I'm not convinced.
Has anyone else encountered this issue. I'm afraid the grinding will eventually cause chips that will eventually lead to tranny failure.
Thoughts?
Paul
Thoughts?
Paul
Received 2,379 Likes
how are you shifting? normally, I am sure......but what does that mean?
5th Gear
mine had a slight grind for a few hundred miles when cold but it went away. sorry to hear yours is persistent.
mine had a similar issue although your appears to be more pronounced. My dealer had a field engineer come and check it out. He ended up adjusting something in the shifter assembly...made a huge difference. Not a single grind ever since. It is a common thing in the new corvettes and most of them need to be just adjusted or calibrated. Your dealer can call mine to inquire. PM me and I will give you more details.
