Problems shifting from 1st to 2nd
I cannot go from 1st gear to second especially when making a left hand turn 50% of the time. The shifter gets stuck (on a gate?) and will not slide rearward into second gear. I have to make sure the shifter is in neutral by wiggling it side-to-side, then it will slide into second. I have almost been hit from the rear several times because of this. Second gear also grinds sometimes during this shift when cold.
Going to have the dealer look into it.
^Hmm could be!
I thought that was merely a suggestion, but in reading the manual, it says that when the message is displayed, 2 & 3rd are locked-out.
Is this mode present in all driving modes? I spend most of my time in T or E (on the freeway).
I hope it can be programmed out with HP Tuner.
Just buy/install a CAGS skip-shift Eliminator.
For $30, and a 5-minute DIY install, the 1-4 forced shift is eliminated.
^Hmm could be!
You will see a Skip Shift message briefly in the center display when this is happening.
I have gotten into the habit over the years of driving GM Skip Shift manuals to do 1-3 shifts when driving leisurely.
The CAGS eliminator is the easiest/cheapest/only warranty friendly way around this nuisance. Or tune it out for free if you're committing to the tune route.
