Penske Shocks C7 Kits now available
The coilover models suggest that they lower 1". I suppose most lowering on the stock bolts is about 3/4" so this might work for the average street tuner.
I would be inclined to use the OEM springs and the coilovers to make a total spring rate about equal to the C6 T1 kits. But I don't see how to match up the ride heights of the OEM springs with the coilovers if the coilovers must be at 1" lower. Basically, don't worry about it but just throw the OEM springs away and put the required spring rate on the coilovers
Any current feedback/discussion on the Penske's? My interest is for stock ride height for street use on rough roads. I'm after more control but maintaining compliance on my base C7. Of course I'm likely to start with Z51 sways and I'm wondering if Z51 shocks would provide what I want or whether the upgrade to Penske's would be worth the cost. I doubt I need adjustability and I don't understand the value of coil overs compared to non-coil overs on a C7.
Since you're non-coilover you'll have the benefit of spherical bearing mounts without putting all of the spring load through the bearings and thereby extending the life/reducing maintenance.
We've also seen our shocks go as far as 30,000 miles between rebuilds but we recommend a minimum of once every two years. If you go to the track much then we recommend at least rebuilding once every year. Overtime the shims and oil will break down and the ride will be a bit more compliant but still night and day over stock shocks. Of course with Penskes you can custom tailor the tune each time you get them rebuilt based on your own feedback with the shock technician.
I hate to say this guys. I'm sure u won't agree because you own c7's but I ended up lossing a lot of money on my car. I bought variant 3 kW coil overs for $4000 and even with dampening to all the way soft almost the spring rate was still to stiff for me. So I sold my 700hp supercharged Vette for way less than I paid for it. The base models suspension is complete junk for a sports car. I knew I wanted the z51 package with magnetic ride control but the supercharged power blinded me. Oh well. U live and learn.
Now it has to be a troll because I said something you don't like? I'm not mechanically inclined. All I know is I did not like the base suspension or the high end coil overs I put on. I got the coil overs put on properly as well.
I think he was just confused like me. You sold your car because a cheap part any mechanic could have replaced didn't perform like you hoped. Most people wouldn't handle the situation like you did hence the confusion.
I'm sorry your professional installers failed to mention this to you. That wasn't very professional of them and I wouldn't go back. The springs are the cheap part and a quick swap almost certainly would have solved your problem.
I'm angry on your behalf that this cost you your time, money, and car. In the future, find a shop that also knows how to setup it up. Any monkey with a wrench can bolt stuff on!
And the stock ride is way to floaty for my taste.
If the spring rate on the coilovers is to stiff no matter what setting u put it at you are going to feel the bumps. Trust me. I had it professionally installed and we tweaked it several times. If the road had no bumps what so ever like a highway it was ok but other than that I was not satisfied. I'm saying this to warn people.
#36
#37
Should've bought a Z51.
Floaty is a function of shocks, not springs.
#40
Received 2,379 Likes
