Whats needed to add F/R Z51 brake cooling ducts to base C7
I'm Batman..
Pro Mechanic
I have a base C7 and plan to upgrade the entire brake system at some point. What is necessary to implement the brake cooling duct system from the Z51 to the base model? Is it even possible?
I would assume I need the two ducts for the rears, the deflectors for the front, two ducts for the front, and possibly different front grill inserts for where the air comes in as these are blocked off on the base model. Is that about right and if so does anyone have the part numbers for these items?
Ant
Ant
I am with you on the addition of Z51 cooling ducts. I know the base has 4 separate part numbers for the upper/lower/, L/R "block offs. So there must be part numbers for the lower L/R Z51 brake ducts openings. I also hope to see some correct Z51 brake duct part numbers on this thread.
I'm Batman..
Pro Mechanic
I went to a Vette show today and took another look at the brakes on a Z51. Looks like there is a duct AND a deflector for each corner of the car. Can anyone with a Z51 confirm this for the front and rear?
Also, I took a pic of the opening on the front grill where the brake cooling duct work begins on the Z51's:
Not sure if this is what you are looking for, but here is a shot of my rear wheel-well with duct visible.
I'm Batman..
Pro Mechanic
