HOW TO: Adding Z51/Z06 Brake Cooling Ducts and Deflectors to Base Stingray
Cruising
Thanks for the detailed instructions. I completed this install yesterday on my car and it went smoothly. I have a lift installed in my garage and I never had to remove the wheels.
Rather than using the plastic clip on the rear ducts I purchased two extra 11609989 bolts to ensure that the plastic wouldn't break. On my '15 Stingray the hole was already threaded.
Great job putting this together.
Thanks to op z...
I have added the Z06 front brake duct kit to the website. You can either just order the base front brake duct kit with hardware or you can add the control arm and rotor cooling deflector kit to go with it.
http://www.cultragfactoryparts.com/c...tbrakeductkit/
Can you post a link or the part numbers for the Z06 Front Control Arm and Knuckle Deflector kit (RH and LH)?
I do not need the duct kit as I purchased that from you a while back without realizing there were other parts needed.
Thanks Dave
I'm Batman..
Pro Mechanic
hmm. I checked them and both the links for the deflectors for the front are working, but the links for the back deflectors are not. You may just need to give them a call and Gene can help you to get the right parts. It is possible the part numbers have changed.
Premium Supporting Vendor
Anthony,
Thank you for the referrals. For now, please contact me directly and I will send you a link to pay for the deflector kits.
For your convenience I will make the website allow you to only order the deflector kits without the brake ducts.
Thank you,
Gene.
Thank you,
Gene.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Phone: 484-334-8833
Thanks to op z...
i called GM today and here are the new parts, they are $50 each
23224729 - Front Brake Cooling Duct RH
23224728 - Front Brake Cooling Duct LH
and here the the other part:
DEFLECTOR KIT - GM (22944235) for $29.59
http://www.gmpartsdirect.com/oe-gm/22944235
#33
Now if you notice at this point you can see a very noticeable gap between the front grill and the duct. This gap is also very ugly from the front of the car as well. On the Z51/Z06's there is a rubber piece surrounding the duct making it a better fit, but still not how I actually chose to mount mine. I actually chose to take a notch out of the plastic mounting area, and put the tab behind the mounting hole. I then used a zip tie to hold it in place like this:
here is a comparison of the factory mounting way and the large gap that it presents outlined and my way of mounting side by side from the front of the car to show the difference:
As you can see it looks much more aesthetically pleasing, and its quite secure in there with the zip tie.
Ant,
Any idea where I could find that rubber seal they use on the Z51/ZO6 to marry the ducting up to the front grille?
#34
I'm Batman..
Pro Mechanic
Ant,
#35
