Header Install Directions (Z51)
Has anyone done a step by step header install for a base or Z51 car?
I realize the coil covers need to be removed, the tunnel brace, x-pipe removed at the collectors, the fuse box on the passenger side, the spark plugs and wires pulled, the bolts removed at the head, the z51 oil lines and the oil drained, the starter needs removed, but was wondering if there are other things I should know in advance.
I see some people removing the valve covers. I heard someone say the passenger side was easier to go in from the top (mid-length). I am installing mid-length too.
Also, is there a valve cover gasket or is it silicone if I do need to remove it. Any other parts I might need since I'm going to be doing it on a holiday week.
This should help: https://www.corvetteforum.com/forums...r-install.html
Just did this.
driver side easy.
pass side major pita
i removed the valve cover on pass side to get more room to work with, its really tight
Both headers went in from the bottom, no way you could do it from the top especially the pass side
driver side easy.
I have never done a late model Camaro or Vette that it would be easier from the top, but this is a new car for me so I definitely like to hear the wisdom of those who have completed the same job.
Thanks for the input.
My midlength just went in. I had to disconnect oil lines but starter stayed . Took a bit of wrestling but both in from beneath.
Premium Supporting Vendor
I always remove the valve covers on the pass side so it's easier.
One thing I can tell you is just because the tsp headers are the longest primaries doesn't make them harder to install. Honestly they're probably the easiest install. No starter removal, no lifting motor up, and some guys claim they didn't remove oil lines. I always did because I was use to trying several different brands and styles in testing. I guess I was in a groove and just repeating steps without considering if there were easier ways!
Removing the oil lines from the sump is no big deal. Drain the oil then unbolt the oil line retainer from the sump. Very simple. The oil lines plug straight in and are sealed to the sump with an "O" ring. A bolt on retainer keeps them in place. So don't let that influence what header to buy.
I'm tackling this job right now. The passenger side has a ton of electrical in the way. I pulled the relay box then removed the five individual relay plugs from the tray then unbolted the tray and removed the coil pack cover. once all that once removed the passenger side was pretty easy. There is a round thing on the driver side and I have no idea what it's for. its mounted with soft rubber mounts. I want to remove it for clearance but don't want to mess with it without knowing its purpose. I think there is less physical space on the driver side. At least on the passenger side you can MAKE space. If anyone knows what the round thing is on the driver side chime in!
