How-To: Remove/Replace Rear Quarter Panel Air Scoops
no idea on the air scoops as there are no parts numbers associated with them yet, just looks like additional scoops in the Z06.
As far as the cooler, a 2015 Z51 cooler 22908628 and lines 22809154
2015 Z06 are cooler 23224810 and lines 23212375
Picture shows the same mounting but have no idea of size/flow changes
Never mind, I found them on a GM parts site for $90.08 a piece. Thanks for the part numbers though!
I'm just buying the vents, I have a Z51 and it already has built in ducts that cool the transmission oil cooler and rear differential. The Z06 vents should catch more air, but I don't think there will be any issues with the factory (Z51) ducts receiving more air from the Z06 vents. But I'm not an expert nor have I tested this theory yet.
Thanks for those part numbers. You showed a diagram of the brake ducts, and I was wondering if there was a similar diagram for the duct that goes between the fender air scoop and the back of the transmission cooler. The picture shows the large black plastic duct on the left above the tire for the Z51 automatic transmission cooler (because it has a fan, manual does not) and the mounting brackets for the cooler. Also wondering if the brackets are the same between Z51 and Z06.
C7 z/OS vents
z/OS vents are not available. Seems GM is saving them for the plant only and not releasing them to over the counter customers. So, Don't do any slicing and dicing until you have em in hand. I think I found a source though. LOL LOL
The following How-To covers the explanation of how to Remove & Replace Rear Quarter Panel Air Scoops and includes specifications, schematics, etc.
These How-To guides are neither endorsed by or property of Corvette Forum or myself in any way/shape/form. All liability stemming from any actions taken in relation to these guides is solely placed upon the user.
We hope you will find these guides useful.
I just bought the ACS Composites vent ducts and the installation procedures looks like only the rear quarter needs to be removed by taking out the three torx bolts on the rear quarter flange (where door meets quarter) and the four torx on the rear quarter mounting flange accessed from the trunk (where trunk lid meets quarter). That allows you to pry the quarter away and access the three retaining nuts.
Haven't tried it yet but Joseph at ACS says shouldn't take more than 30 mins.
Guys,
#35
You'll need a plastic pry tool, T15 torque head, and a 8mm wrench. I was able to do both sides in probably 2 1/2 hours taking my time and not being 109% sure. The rubber under the quarter panel glass was a bitch as well, you have to use the pry tool on the top end to allow the rubber to stay on top of the quarter panel when reinstalling.
#36
Yes I just removed the top 4 torq screws and the three in the door well (three in fuel cap on drivers side). Then used plastic interior pry tools to help pull the quarter panel out. Drivers side was easier then the passenger, but both were a pain in the *** to get to the top nut on the vent. If you have skinny hands you'll be fine but if you got fat/big hands then you might want to use a different method (remove the rear bumper) or pay someone to do it.
#37
Just a warning all, don't shortcut this job. I took it to a GM body shop and it was a major PITA. They followed the ACS instructions and ended up catching an edge on the stock vents removing them, it scratched the quarter and the car ended up getting a painted fender trying to remove these.
Remove the rear bumper and then remove the whole panel, disassemble the duct off the car if you want to save your paint. Stupid design how they go in.
#38
Any one tried this C7 Z51 scoop enhancer?
I got my A8 transmission to overheat on track (Watkins Glen, air temperature 39F - that is 3C) in about 15min even while minimizing shifts/lap, and upshifting at around 5,500-6,000RPMs (not near redline).
The overheating is the only problem I have with enjoying my Z51 that I haven't been able to solve.
Last edited by Zymurgy; 05-03-2015 at 06:17 PM. Reason: Advertising for non-supporting vendor not allowed
#40
Yes, but take about 10 seconds to install, without removing anything, vs 3 hours+ and the risk of a required fender paint job on a brand new car.
If I knew these were effective, I'd buy them instantly.
Wondering if anyone has tried and seen any reduction in transmission fluid temperature.
