Flex Fuel Sensor install
#162
On other flex fuel setups I've noticed that the sensor has a bypass route when it is positioned on the high pressure side of a fuel system.....
In all the pics in this thread, I don't see a bypass loop?
Isn't this going to be a flow restriction at a certain power level?
Or is the sensor capable of outflowing the factory feedline?
#163
#164
In terms of enabling flex fuel is what you detailed below everything that has to be done in the tune? If so I need to check to see that EFILive has all of those tables/DTCs available.
Simple, I believe Pace Performance is vendor so Ill post some links
Flex Fuel sensor part number 13577429(my favorite, OEM, cheaper and more compact)
http://paceperformance.com/i-1080149...ensor-e85.html
Connector part number 13352241 (cut the end off and use the 3 existing wires) sensor pigtail has a black (ground), pink (Power), and a white (ECM). ECM C7 Pin is X1 Pin 38
http://paceperformance.com/i-8396465...r-harness.html
Use the factory Fuel line to connect to the entry end of the Flex fuel sensor and use a 3/8 quick disconnect to connect to the other end of the sensor and then connect to factory fuel supply entering the rail. I bought a C5 factory braided hose that is long enough and has the perfect ends, entire install will look OEM and be somewhat hidden.
Ill have everything Saturday and I will get pics up this weekend.
Here are the most important tables In the calibration dealing with E85
I can explain the tables if anyone wants additional input
Also go into DTC's and enable P0178 and P0179 which deals with the High/Low Circuit for the Flex fuel sensor(Pic is Above)
Also, as many of you can see the Spark tables are there and just needs the Stoich table modified like above. The C7 Z06 however all tables are Zeroed out dealing with alcohol. Some have reported in the tuning world enabling Alcohol ONLY with no changes of the Spark tables and gain 4MPH and 40hp. Basically for around $150 you can have C6 Z06 power, best bang for the buck mod I know of.
#166
No, I have not listed my tune details as it's being used for retail. Those details shared were from another forum member
#167
Thanks. I realize that. I don't expect anyone that paid for a tune to give away info. That is not fair for either customer or the tuner.
I was thinking that T/A Kid (or others) have been doing their own tuning and flex fuel enabling.
Once I figure out what EFILive has or doesn't have I will post the details here so that everyone knows.
If EFILive can do the job I'll post screen shots and an Excel spreadsheet so that the values can be easily cut and pasted as well.
#168
#174
just got done installing mine, real easy overall. Hardest part was the 10mm fender bolt on the inside of the fender. Once the connector was removed, I could fish it out between the fender on door. Had pleanty of room to open connector and insert pin. All good, vehicle runs normally. Now to get it to the tuner to make sure I did everything correct and it sees the sensor. More after next week
PS: my side skirts will be in late next week, glad I did this before I installed those...
#175
Anyone running flex fuel and boost without meth? Is there enough pump to see the advantages of e85 on say 7-8 psi?
#176
Nice looking setup from Dave. It looks like power and ground come from small harness in the picture. I assume that something is unplugged and then you just plug in the small harness.
#177
Received 2,379 Likes
#178
Yes, Dave unplugs any of the coils and installs a jumper harness, truly plug-n-play. Even the wire for the ECU is stamped with the proper wording in case anyone sees it and wonders what it is and has the correct pin for the ECU. 5 minute install for the main part, about an hour to do the ECU, most of that time is getting access to the inner Rt Fender.
#179
Great job on the install!!! looks awesome, and enjoy that new power once the tune is finished. Car really opens up
#180
Yes, Dave unplugs any of the injectors and installs a jumper harness, truly plug-n-play. Even the wire for the ECU is stamped with the proper wording in case anyone sees it and wonders what it is and has the correct pin for the ECU. 5 minute install for the main part, about an hour to do the ECU, most of that time is getting access to the inner Rt Fender.
